I found out today that because the license server is on Citrix, our local desktops/laptops won't be able to borrow (in ArcGIS 10) any licenses because it cannot directly connect to the license server. (The Citrix farm is in another city) This is a big drawback for us as we have users that go out in the field where there is no cellphone/internet coverage.
We are in the process of doing the same thing with ArcGIS 10. We are putting it on a Citrix6 Farm on Server 2008 R2 servers.To solve the printing issue, we have created a print server that is in the data center that is local to our Citrix farms. This allows the print jobs to off load the terminal servers quickly. When then have the print servers print directly to the local/network printers inthe various offices directly across the WAN. In our testing phase this is what yielded us the best results for printing.Still, I was hoping there would be others with a Citrix 6 and ArcMap 10 environment that I could do more reading on so I can know how to optimize my Citrix installation to get the best performance for my environment.
I am not able to personally test this without access to a Citrix environment, but I double checked with a couple of sources that say you should be able to borrow a license from the license manager that is running in the Citrix environment as long as the client can connect to it. Maybe you could provide more details (error messages, connectivity issues, etc.)
Julie -Is the poor performance on client side systems only? For example, if you can find a way to remote into the Citrix box (Win2k8) using RDP, do you find the performance remains slow? Also, running Task Manager on the Citrix box, how many ArcMap.exe's do you see running? ArcMap is a pretty hefty product it is quite easy to overwhelm a Citrix server with only a few clients.
Does anyone know how to change the default.gdb location for users accessing ArcGIS Desktop 10 in Citrix? I don't want the server filling up with these default GDBs. Also, I'd like to know how to redirect this local cache folder to the user's home drive and not a folder on the citrix server. Any thoughts?
HiWe are currently looking to deploy ArcGIS on Citrix across our Authority. Does anybody have any experience of running ArcGIS on Citrix as opposed to Desktop clients? We are especially interested in known issues/ performance and optimum settings for improving speed, which initial testing has shown to be very slow. We will be running on a minimum version of 9.3, but possibly 10.Any help or advise would be much appreciated!Thanks
Though I earlier in this thread stated that we have experienced little to no problems in using the Citrix Deployment method for ArcGIS, there have been a few little pesky items. One of which follows:When I thry to author and serve out a map (either through ArcServer or Publisher) using ArcGIS through the Citrix connection, the data links break and the end user (web or ArcReader) sees only the data holder in the TOC along with the broken link symbol. Same map is then opened in ArcGIS on a local install, the data sources reset to exactly what they were before(but resetting is required), then the maps as served out (via ArcServer or Publisher) contain active links and all is well.After researching this a bit, I did discover that when looking at the data sources for the .MXD file in ArcCatalog, the connection file found on the \Application Data\ESRI\ArcCatalog\[connection].sde path was set to where the IT folks are preserving the profile information that Citrix uses when a user is logging in. (see attached).The data source file is shown on another computer - in this case:\\rcg-file1\appdata$\jearmstrong\Application Data\ESRI\ArcCatalog\SdeConnect@richmond_vector.sde - this is where the user profiles are being storedNormally this connection would be "Database Connections\SdeConnect@richmond_vector.sde" which seems to resolve to C:\Documents and Settings\[username]\Application Data\ESRI\ArcCatalog\Admin@richmond_vector.sde.Is there a way to set this data connection path to allow data in a map service authored through the Citrix deployment of ArcGIS to be viewable by the end users? I realize there is a manual workaround, but that kind of defeats the purpose of running the GIS through Citrix. I hope somebody can shed some light on this issue.thanksJames ArmstrongRichmond County, North CarolinaGIS
You can probably get what you are looking for by enabling "Special Folder Redirection," a Citrix concept will push the GDBs created for each profile back to the client (http://support.citrix.com/proddocs/index.jsp?topic=/web-interface-hardwick/wi-enable-special-folder-redirection-gransden.html). BUT....be advised that enabling "Special Folder Redirection" within Citrix results in a considerable performance loss from the client side as data that normally would be locally available to the Citrix server now has to traverse the LAN/WAN link between client and server. (Among a host of other complications).
instead of pushing them back to the client, I would like to push them to the user's "home" drive which is on the local network with the Citrix server. Does this special folder redirection accomplish that? I'd also like to redirect the cache folder to their home drive as well.
Mark, We are having the exact same issue where we get the "unable to open...", but is we are admin or logged into the desktop the image (tif) opens successfully. Did you ever find what caused this problem?Thanks,Scott BarkerAlabama Gas
ESRI Support asked to me to test that as well. When a user used RDP to remote in, the peformance was 'normal'. When I run Task Manager, I only see my own apps running. We only have 10 users (clients) on a 16 CPU and 12GB Ram server (new since June 2010). The CPU usage rarely goes beyond 10%, memory usage is usually around 5GB. Performance was also extremely slow when only 1 user (administrator) was logged on. I don't think we are overwhelming our Citrix server...Thanks for your feedback! Any other suggestions to try?Julie
If anyone is experiencing visual artifacts with ArcGIS 10.x (or prior release) on Citrix, reducing Application Color Depth to 16-bit color seems to address a number of these issues. (Citrix Access Management Console > Farm > Application > ArcMap > Properties > Advanced > Appearance > Colors > Set to 16-bit)Most notably, recently we found that Citrix clients running ArcGIS 10.0 / XenApp 4.x / Windows 2003 Server are unable to render the "ArcGIS Online" browser from within ArcMap. Reducing ArcMap color depth to 16-bit addresses this issue.* The issue does not surface with ArcGIS Desktop 10.0 / XenApp 5.x / Windows 2008 Server.I'll continue to post these "tips" as we run across them.
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
