I have been looking around the internet all morning to figure out how to write a Python script to accomplish what I need to do, and so far, I am not finding what I need. Need to see if someone can start me in the correct direction.
I have (2) text fields:
ACALARA TYPE and ACALARA MODEL with coded meter type attributes
Another field:
ACALARA METER TYPE will hold the actual Meter Type
The data in the first two fields is held in a different database and I have a Python script built that will take that data and update these Feature Class Fields.
What I need to do is build a second python script that is composed of an if/else statement.
EXAMPLE:
If ACALARA TYPE = 75 and ACALARA MODEL = 130
Then the ACALARA METER TYPE field will update to show "CEN3S4S20"
If ACALARA TYPE = 109 and ACALARA MODEL = 2
Then the ACALARA METER TYPE field will update to show "UMT2.1"
There are around 2 dozen other combinations with additional Meter Type outputs that I will have to include
Figuring out how to write this code will help with other Feature Classes that I have been updating manually.
Thank You
