<SPAN style="color: #333333; font-family: 'Helvetica Neue', Helvetica, Arial, sans-serif; background-color: rgba(248, 248, 248, 0.6);">Hi, I have carried out a queryTask on a map service that returns a polygon when I input a postcode. Within the same service, there is an additional layer where I want to query a local authority name on. I would like to carry out a querytask on this layer at the same time so that the map returns a polygon relating to the postcode input and also tells me what local authority it is contained within. I will ultimately show the local authority as text in a separate widget. Can anyone help please? Here's my code so far with the second queryTask cancelled out near the middle as I'm not sure where it should go??</SPAN>
function showResults(results) {
var resultItems = [];
var resultCount = results.features.length;
for (var i = 0; i < resultCount; i++) {
var featureAttributes = results.features<I>.attributes;
var graphic = results.features<I>;
graphic.setSymbol(symbol);
map.graphics.add(graphic);
//var queryTask2 = new QueryTask("http://rest/services/live/SEARCH/MapServer/15");
//query2 = new.esri.tasks.Query();
//query2.returnGeometry - false;
//query2.where = ""</I></I>
var strNum = 100;
var newExtent = graphic.geometry.getExtent();
newExtent.xmin = newExtent.xmin - strNum;
newExtent.ymin = newExtent.ymin - strNum;
newExtent.xmax = newExtent.xmax + strNum;
newExtent.ymax = newExtent.ymax + strNum;
map.setExtent(newExtent);
for (var attr in featureAttributes) {
resultItems.push("<b>" + attr + ":</b> " + featureAttributes[attr] + "<br>");
resultItems.push("<br>");
dom.byId("info").innerHTML = resultItems.join("");
dom.byId("results")
function addToMap(result) {
debugger;
var query = new Query();
query.returnGeometry = true;
query.outFields = [
"POSTCODE"
on(dom.byId("execute"), "click", execute);
function execute() {
query.text = dom.byId("Postcode").value;
queryTask.execute(query, showResults);
