I am working on moving from ArcMap with Attribute Assistant to Pro with Attribute Rules and just needed some clarification that I couldn't find by Googling.
Adding attribute rules impacts backward compatibility for the dataset.
- Datasets with attribute rules can no longer be used by ArcGIS Pro releases prior to 2.1 or ArcMap clients.
My question is about the meaning of "Dataset". When adding Attribute Rules to a Feature Class on an SDE, do the rules only effect the single Feature Class, or would the entire SDE no longer be backwards compatible with ArcMap?
