memory leak in mapcontrol
Hello all, I'm using dynamic mode to draw polylines in the mapcontrol, the codes are as follows. After running the program, the lines are drawn, but I found the memory was increasing all the time, anyone please help me to find the issue? thanks!
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using ESRI.ArcGIS.Controls;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.esriSystem;
namespace MapMemTest
public partial class Form1 : Form
IMapControl4 m_mapControl = null;
Timer stoptimer = new Timer();
private IMap m_map;
private IActiveView m_activeView;
private IDisplay m_display;
private IDynamicMap m_dynamicMap = null;
private bool m_bIsDynamicMode = false;
protected object Missing = Type.Missing;
public Form1()
InitializeComponent();
Init();
void Init()
m_mapControl = axMapControl1.Object as IMapControl4;
m_mapControl.Extent = m_mapControl.FullExtent;
m_activeView = m_mapControl.Map as IActiveView;
m_dynamicMap = m_mapControl.Map as IDynamicMap;
if (!m_bIsDynamicMode)
//switch into dynamic mode
if (!m_dynamicMap.DynamicMapEnabled)
m_dynamicMap.DynamicMapEnabled = true;
//start listening to DynamicMap's 'After Draw' events
((IDynamicMapEvents_Event)m_dynamicMap).AfterDynamicDraw +=
new IDynamicMapEvents_AfterDynamicDrawEventHandler(Form1_AfterDynamicDraw);
stoptimer.Enabled = true;
stoptimer.Interval = 500;
stoptimer.Tick += new EventHandler(stoptimer_Tick);
void Form1_AfterDynamicDraw(esriDynamicMapDrawPhase DynamicMapDrawPhase, IDisplay Display, IDynamicDisplay dynamicDisplay)
if (esriDynamicMapDrawPhase.esriDMDPDynamicLayers != DynamicMapDrawPhase)
return;
DrawLineMemTest(dynamicDisplay);
void DrawLineMemTest(IDynamicDisplay dynamicDisplay)
IPointCollection4 pointcoll0 = new PolylineClass();
IPoint p0 = new PointClass();
List<IPoint> tmppoints = new List<IPoint>();
int pointcount = 1801;
WKSPoint[] points = new WKSPoint[pointcount];
int tmpcount = 0;
for (double i = -90; i < 90; i += 0.1)
WKSPoint wksp;
wksp.X = i;
wksp.Y =i;
points[tmpcount] = wksp;
tmpcount++;
IGeometryBridge2 pGeoBri = new GeometryEnvironmentClass();
pGeoBri.AddWKSPoints(pointcoll0,ref points);
DynamicDrawLine(pointcoll0, 230, 0, 0, 2, dynamicDisplay);
void stoptimer_Tick(object sender, EventArgs e)
m_activeView.PartialRefresh(esriViewDrawPhase.esriViewGeography, null, null);
void DynamicDrawLine(IPointCollection linePointColl, byte r, byte g, byte b,
double width, IDynamicDisplay dynamicDisplay)
m_dynamicSymbolProps = dynamicDisplay as IDynamicSymbolProperties2;
m_dynamicSymbolProps.SetScale(esriDynamicSymbolType.esriDSymbolLine, (float)width, (float)width);
m_dynamicSymbolProps.SetColor(esriDynamicSymbolType.esriDSymbolLine, (float)r / 255, (float)g / 255, (float)b / 255, 1.0f);
dynamicDisplay.DrawPolyline(linePointColl);
