Planning to migrate production web services from 10.3.1 to 10.6.1 in a couple months. We're migrating/staging everything on an entirely new server. The last step will be to switch over the DNS entry from our current 10.3 production server to the new 10.6 instance. The backend data sources will not change.
Here's my question/concern: if an end user has content in Collector that originates from 10.3 and then the DNS entry switches over to the new 10.6 server and they try to sync will it fail? The REST endpoint URL will be the same. The backend database/datasource will be the same. It should be transparent and I'm hoping that Collector is none the wiser and that ArcGIS Server (either version) simply brokers the transaction but doesn't place any holds or dependencies.
