I am trying to make an offline app that records the GPS over time and when it is connected to Wifi, it takes all of the stored GPS points in the array and pushes them up to a featureservices online. I have experience with google maps API but this is my first application using ArcGIS Android SDK. Any help would be appreciated.
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">OfflineGPS</SPAN> <SPAN class="keyword token">extends</SPAN> <SPAN class="token class-name">AbsRuntimePermission</SPAN> <SPAN class="punctuation token">{</SPAN>
ArrayList<SPAN class="operator token"><</SPAN>Double<SPAN class="operator token">></SPAN> arrLat <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArrayList</SPAN><SPAN class="operator token"><</SPAN>Double<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ArrayList<SPAN class="operator token"><</SPAN>Double<SPAN class="operator token">></SPAN> arrLng <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArrayList</SPAN><SPAN class="operator token"><</SPAN>Double<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ServiceFeatureTable sft<SPAN class="punctuation token">;</SPAN>
Portal portal<SPAN class="punctuation token">;</SPAN>
ListenableFuture<SPAN class="operator token"><</SPAN>List<SPAN class="operator token"><</SPAN>FeatureEditResult<SPAN class="operator token">>></SPAN> listListenableFuture<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">static</SPAN> <SPAN class="keyword token">final</SPAN> <SPAN class="keyword token">int</SPAN> REQUEST_PERMISSION <SPAN class="operator token">=</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">;</SPAN>
@Override
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">onCreate</SPAN><SPAN class="punctuation token">(</SPAN>Bundle savedInstanceState<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">super</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">onCreate</SPAN><SPAN class="punctuation token">(</SPAN>savedInstanceState<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
sft <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ServiceFeatureTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fservices3.arcgis.com%2FfRxd0TMcSb4qCvqU%2FArcGIS%2Frest%2Fservices%2Fsignsurvtracking%2FFeatureServer%2F0" target="_blank">https://services3.arcgis.com/fRxd0TMcSb4qCvqU/ArcGIS/rest/services/signsurvtracking/FeatureServer/0</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
sft<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addDoneLoadingListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Runnable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
@Override
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
Feature feature <SPAN class="operator token">=</SPAN> sft<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setGeometry</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getGeometry</SPAN><SPAN class="punctuation token">(</SPAN>arrLng<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getGeometry</SPAN><SPAN class="punctuation token">(</SPAN>arrLat<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttributes</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">put</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"description"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DESCIPTION"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
sft<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addFeatureAsync</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addDoneListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Runnable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
@Override
listListenableFuture <SPAN class="operator token">=</SPAN> sft<SPAN class="punctuation token">.</SPAN><SPAN class="token function">applyEditsAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
listListenableFuture<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addDoneListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Runnable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
@Override
<SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>FeatureEditResult featureEditResults <SPAN class="operator token">:</SPAN> listListenableFuture<SPAN class="punctuation token">.</SPAN><SPAN class="token function">get</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
Log<SPAN class="punctuation token">.</SPAN><SPAN class="token function">e</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"TEST"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Fetaure Edit Results"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
Log<SPAN class="punctuation token">.</SPAN><SPAN class="token function">e</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"TEST"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ObjectID"</SPAN> <SPAN class="operator token">+</SPAN>featureEditResults<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getObjectId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>EditResult er <SPAN class="operator token">:</SPAN> featureEditResults<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttachmentResults</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
Log<SPAN class="punctuation token">.</SPAN><SPAN class="token function">e</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"TEST"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"OBID"</SPAN> <SPAN class="operator token">+</SPAN> er<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getObjectId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">InterruptedException</SPAN> e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">printStackTrace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">ExecutionException</SPAN> e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
sft<SPAN class="punctuation token">.</SPAN><SPAN class="token function">loadAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
arrLng<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
arrLat<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
