I can do it with a basic arcpy.da.UpdateCurosr but I am trying to figure out how to use arcpy.da.UpdateCurosr with dictionary key. I am trying to populate Field1 if the row is blank but if not then continue on to the next row. I have the following but I get error,
upd_row[0] = search_feats[upd_row[1]] #FIELD_2
KeyError: 'Blah Text'
>>> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
flds = ['Field1','Field']
search_feats = {f[0]:f[1:] for f in arcpy.da.SearchCursor(fc1, flds)}
with arcpy.da.UpdateCursor(fc1, flds) as upd_cur:
for upd_row in upd_cur:
#if upd_row[0] is None:
if upd_row[0] != None:
#if upd_row[0] in ("", ' ', None):
upd_row[0] = search_feats[upd_row[1]] #FIELD1
upd_cur.updateRow(upd_row)
del upd_cur<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
