See below:
<SPAN class="">require</SPAN><SPAN class="">([</SPAN><SPAN class="">"esri/Map"</SPAN><SPAN class="">,</SPAN><SPAN class="">"esri/views/MapView"</SPAN><SPAN class="">],</SPAN><SPAN class=""> </SPAN><SPAN class="">function</SPAN><SPAN class="">(</SPAN><SPAN class="">Map</SPAN><SPAN class="">,</SPAN><SPAN class=""> </SPAN><SPAN class="">MapView</SPAN><SPAN class="">)</SPAN><SPAN class=""> </SPAN><SPAN class="">{</SPAN><SPAN class="">
</SPAN><SPAN class="">var</SPAN><SPAN class=""> map </SPAN><SPAN class="">=</SPAN><SPAN class=""> </SPAN><SPAN class="">new</SPAN><SPAN class=""> </SPAN><SPAN class="">Map</SPAN><SPAN class="">({</SPAN><SPAN class=""> basemap</SPAN><SPAN class="">:</SPAN><SPAN class=""> </SPAN><SPAN class="">"streets"</SPAN><SPAN class=""> </SPAN><SPAN class="">});</SPAN><SPAN class="">
</SPAN><SPAN class="">var</SPAN><SPAN class=""> view </SPAN><SPAN class="">=</SPAN><SPAN class=""> </SPAN><SPAN class="">new</SPAN><SPAN class=""> </SPAN><SPAN class="">MapView</SPAN><SPAN class="">({</SPAN><SPAN class="">
container</SPAN><SPAN class="">:</SPAN><SPAN class=""> </SPAN><SPAN class="">"viewDiv"</SPAN><SPAN class="">,</SPAN><SPAN class="">
map</SPAN><SPAN class="">:</SPAN><SPAN class=""> map</SPAN><SPAN class="">,</SPAN><SPAN class="">
center</SPAN><SPAN class="">:</SPAN><SPAN class=""> </SPAN><SPAN class="">[-</SPAN><SPAN class="">97.744483</SPAN><SPAN class="">,</SPAN><SPAN class=""> </SPAN><SPAN class="">30.272705</SPAN><SPAN class="">],</SPAN><SPAN class="">
zoom</SPAN><SPAN class="">:</SPAN><SPAN class=""> </SPAN><SPAN class="">15</SPAN><SPAN class="">,</SPAN><SPAN class="">
console</SPAN><SPAN class="">.</SPAN><SPAN class="">log</SPAN><SPAN class="">(</SPAN><SPAN class="">view</SPAN><SPAN class="">.</SPAN><SPAN class="">allLayerViews</SPAN><SPAN class="">.</SPAN><SPAN class="">items</SPAN><SPAN class="">);</SPAN>
<SPAN class="">console</SPAN><SPAN class="">.</SPAN><SPAN class="">log</SPAN><SPAN class="">(</SPAN><SPAN class="">view</SPAN><SPAN class="">.</SPAN><SPAN class="">allLayerViews</SPAN><SPAN class="">.</SPAN><SPAN class="">length</SPAN><SPAN class="">);</SPAN><CODE><SPAN class="">console</SPAN><SPAN class="">.</SPAN><SPAN class="">log</SPAN><SPAN class="">(</SPAN><SPAN class="">view</SPAN><SPAN class="">.</SPAN><SPAN class="">allLayerViews</SPAN><SPAN class="">.</SPAN><SPAN class="">items</SPAN><SPAN class="">[</SPAN><SPAN class="">0</SPAN><SPAN class="">]);
<IMG __jive_id="372765" alt="" class="image-2 jive-image j-img-original" src="https://us.v-cdn.net/6038851/uploads/legacyfs/online/372765_img2.png" style="height: auto;" />
</SPAN>
I suppose the array calls are accessing the Array prototype, but I don't know how to make it not do that. I would like to be able to loop through the layerViews with forEach().
