How to customzie an ArcGIS Online Web Viewer
Hi all
I am looking for a web template where I can add customized code or set up the the following features:
??? Toolbar with the following buttons:
o Zoom in , Zoom Out, Pan, Zoom Full Extent, Previous Extent, Next Extent
o Select by Point, Select By Rectangle, By Polygon, by Circle,
o Buffer, Measure, Overview
o Find by address, Intersection
o Tracing, Printing, Help
??? Base map toolbar, shows custom maps instead of Esri base maps
??? Map section, shows map, overview window, loading map image, popup results window
??? Right panel
o Layers list, interactive when check/uncheck layer maps refreshes
o Legend
??? Multi search floating panel, search by address, intersection, folio, etc,
Could it be done adding JavaScript coce to the online template?
