Arcadeには詳しくありませんが、簡単な式を作ろうとしています。住所番号で住所にラベルを付けるif-else式を書きたいのですが、住所のユニット番号がある場合は、そのユニット番号をラベルに表示したいです。このドキュメントを調べました https://developers.arcgis.com/arcade/function-reference/logical_functions/ 。次のような文が必要です。住所がNullでなければ住所を表示し、そうでなければユニット番号を表示する、というものです。Arcadeの構文に詳しくないので、よく分かりません。
FYI, You might have to use feature notation..., meaning it might be
iif(isEmpty($feature.addrunit),$feature.addrnmbr,$feature.addrunit)
Can you share how your data looks like and provide an example of what you would like to obtain for the different situations?
I need the address numbers to display/label by default, unless there is an address for the unit. There can be many units associated to the one address and we need to display these. For example, a parcel with 10 units should display the 10 unit numbers as separate points, but there is still an individual point with just the address number that should be displayed as well.
Sorry, this is my first time using Geonet and I added a new comment rather than replying. I'm not to sure if you will receive a notification from my comment so i'm replying here.
Try combining the "isEmpty()" and the "iif()" logic functions, which works similar to the if-function in Excel:
IIf( condition, trueValue, falseValue )
in your case, it sounds like it would be
Here's the Arcade Function Reference list for your reference:
Hi Nevin Valles , adding a reply to the same thread is the way to go. I'm sorry that I did not answer before, but the answer provided by Diana Lavery should be the way to go (if the field is really empty). Can you please try that suggestion? If it works, please mark her post as the right answer.
Hi Diana,
I'm still not getting the labels to display correctly. It is displaying only some of the ADDRNMBR's and some of the ADDRUNIT's.
Perhaps the field is not really Empty (Null) and contains a space or something similar. This could explain the behavior.
Labels are a dynamic thing in ArcGIS Online. The features that actually get labels to show up will probably change as you zoom in & out, and pan around. At least that's been my experience.
Can you share your map?
Xander was correct because there were records in the field that had spaces, once I reclaculated the expression worked perfectly! Thank you for the expression Diana and thank you for the correction Xander!
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
