I want to show a web-map including feature layer in my hybrid app.
Therefore, I followed instructions here: GitHub - jwasilgeo/ionic-esri-map: An Ionic app demonstrating how to use the Esri ArcGIS API for JavaScript.
I renamed the fullscreen.html to index.html.
In addition, I added zoom and extent (which works).
However, adding the feature layer doesn't work. Any suggestions how to add a feature layer correctly? Or can I add the webmap (with the feature layer) itself?
Thanks in advance!
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no, width=device-width">
<title></title>
<meta http-equiv="Content-Security-Policy"
content="
default-src
'self'
http://js.arcgis.com
http://static.arcgis.com
http://services.arcgisonline.com
http://server.arcgisonline.com;
font-src
'self'
data:;
style-src 'self' http://js.arcgis.com 'unsafe-inline';
script-src 'self' http://js.arcgis.com http://unpkg.com 'unsafe-eval'">
<link href="lib/ionic/css/ionic.css" rel="stylesheet">
<!-- load Esri CSS -->
<link rel="stylesheet" href="http://js.arcgis.com/3.16/esri/css/esri.css">
<!-- IF using Sass (run gulp sass first), then uncomment below and remove the CSS includes above
<link href="css/ionic.app.css" rel="stylesheet">
<style>
html, body, #esriMap {
padding: 0;
margin: 0;
height: 100%;
</style>
<!-- ionic/angularjs js -->
<script src="lib/ionic/js/ionic.bundle.js"></script>
<!-- cordova script (this will be a 404 during development) -->
<script src="cordova.js"></script>
<!-- load Esri JSAPI -->
<script src="http://js.arcgis.com/3.16/"></script>
<!-- load angular-esri-map -->
<script src="http://unpkg.com/angular-esri-map@1"></script>
<!-- your app's js -->
<script src="js/fullscreen/app.js"></script>
<script src="js/fullscreen/controllers.js"></script>
<script src="js/fullscreen/services.js"></script>
</head>
<body ng-app="starter">
<esri-map
id = "esriMap"
map-options="{
basemap : 'topo',
center: [4.91, 52.36],
zoom: 13
<esri-feature-layer
url='https://services8.arcgis.com/QVnoktcHDRrlMUCe/arcgis/rest/services/Panden_Amsterdam/FeatureServer/0'
</esri-feature-layer>
</esri-map>
</body>
</html>
