I am trying to add an combobox to the title of an infoWindow. The combobox is intended to be populated with the list of identified results. I'm trying two different ways:
1. Adding the combobox declaratively using html:
var template = new esri.InfoTemplate(layerName + "<br/><select id="id_select" data-dojo-type="dijit/form/Select"</select>,"<br/> FID : ${FID}");
The combobox is there, but I don't know how to access the combobox to add the options dynamically (via addOptions). I would normally do dijit.byId("id_select"), but considering it doesn't exist until it's created...I'm not sure how to go about this way.
2. Programmatically
With the code below, the title displays information regarding the dijit/form/select widget (It displays: [object HTML TableElement]), but not the widget itself. I tried using domConstruct like this example.
var identifyTask, identifyParams, idPoint;
var identifyResults;
require([
"esri/dijit/Popup",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"dijit/form/Select",
"dojo/dom-construct",
"dojo/promise/all",
"dojo/domReady!"
], function (
Popup, IdentifyTask, IdentifyParameters, Select, domConstruct, All
var identifySelect;
//dojo.connect(window.myMap, "onLoad", mapReady);
mapReady(window.myMap);
function mapReady(map) {
dojo.connect(window.myMap, "onClick", runIdentifies);
function runIdentifies(evt) {
identifyResults = [];
idPoint = evt.mapPoint;
var layers = dojo.map(window.myMap.layerIds, function (layerId) {
return window.myMap.getLayer(layerId);
layers = dojo.filter(layers, function (layer) {
if (layer.visibleLayers[0] !== -1) {
return layer.getImageUrl && layer.visible
}); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers
var tasks = dojo.map(layers, function (layer) {
return new IdentifyTask(layer.url);
}); //map each visible dynamic layer to a new identify task, using the layer url
var defTasks = dojo.map(tasks, function (task) {
return new dojo.Deferred();
}); //map each identify task to a new dojo.Deferred
var params = createIdentifyParams(layers, evt);
var promises = [];
for (i = 0; i < tasks.length; i++) {
promises.push(tasks.execute(params)); //Execute each task
var allPromises = new All(promises);
allPromises.then(function (r) { showIdentifyResults(r, tasks); });
function showIdentifyResults(r, tasks) {
var results = [];
var taskUrls = [];
var resultNames = [];
r = dojo.filter(r, function (result) {
return r[0];
for (i = 0; i < r.length; i++) {
results = results.concat(r);
for (j = 0; j < r.length; j++) {
taskUrls = taskUrls.concat(tasks.url);
results = dojo.map(results, function (result, index) {
var feature = result.feature;
var layerName = result.layerName;
var serviceUrl = taskUrls[index];
resultNames.push({
value: result.layerName,
label: result.layerName
feature.attributes.layerName = result.layerName;
var identifiedList = getIdentifiedList(resultNames);
console.log(identifiedList);
var template = new esri.InfoTemplate();
template.setTitle(identifiedList);
feature.setInfoTemplate(template);
var resultGeometry = feature.geometry;
var resultType = resultGeometry.type;
return feature;
if (results.length === 0) {
window.myMap.infoWindow.clearFeatures();
} else {
window.myMap.infoWindow.setFeatures(results);
window.myMap.infoWindow.show(idPoint);
identifySelect.on('change', function(evt) {
var identIndex = identifySelect.get("value");
console.log(identIndex);
window.myMap.infoWindow.select(identIndex);
return results;
function getIdentifiedList(options) {
identifySelect = new Select({
options: options
}, domConstruct.create("select"));
return identifySelect.domNode;
function createIdentifyParams(layers, evt) {
var identifyParamsList = [];
identifyParamsList.length = 0;
dojo.forEach(layers, function (layer) {
var idParams = new esri.tasks.IdentifyParameters();
idParams.width = window.myMap.width;
idParams.height = window.myMap.height;
idParams.geometry = evt.mapPoint;
idParams.mapExtent = window.myMap.extent;
idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
var visLayers = layer.visibleLayers;
if (visLayers !== -1) {
var subLayers = [];
for (var i = 0; i < layer.layerInfos.length; i++) {
if (layer.layerInfos.subLayerIds == null)
subLayers.push(layer.layerInfos.id);
idParams.layerIds = subLayers;
} else {
idParams.layerIds = [];
idParams.tolerance = 5;
idParams.returnGeometry = true;
identifyParamsList.push(idParams);
return identifyParamsList;
