I was writing a code to compare the fields within some feature classes that are in 2 seperate geodatabases. The geodatabses contain the same feature classes, but the feature classes have different fields.- Loop through first geodatabase
- Loop through second geaodatabase and find the matching feature class
- Loop through the matching feature classes and print the list of fields for each into a spreadsheet
My following code wasn't working, and I narrowed it down to the loop through the second feature class. I went back and the syntax requires that a workspace be set to list feature classes. I did that using env.workspace
but that only sets a workspace for the first geodatabase. I tried setting variables to 2 different workspaces (workspace1 and workspace2) but that doesn't seem to work. Can someone suggest how to set seperate workspaces so I can loop through 2 different geodatabases in the same script?
import arcpy, xlwt, traceback, sys
from arcpy import env
from xlwt import *
workspace1 = env.workspace = r"Z:\test1.gdb"
workspace2 = env.workspace = r"Z:\test2.gdb"
try:
# Create the excel workbook
book = Workbook()
z = 2
x = 2
y = 1
for fc in arcpy.ListFeatureClasses(workspace1):
print fc
for fc2 in arcpy.ListFeatureClasses(workspace2):
print fc2
if fc == fc2:
print fc + " = " + fc2
sheet1 = book.add_sheet(fc)
sheet1.write(0,0, fc)
sheet1.write(1,0, "IOR Field Name")
sheet1.write(1,1, "IOR Field Type")
sheet1.write(1,2, "Field Length")
sheet1.write(1,5, "JC Field Name")
sheet1.write(1,6, "JC Field Type")
sheet1.write(1,7, "JC Field Length")
sheet1.col(0).width = 8000
sheet1.col(1).width = 3000
sheet1.col(2).width = 3000
sheet1.col(5).width = 8000
sheet1.col(6).width = 3000
sheet1.col(7).width = 3000
y += 1
for field in arcpy.ListFields(fc):
x+=1
sheet1.write(x,0, field.name)
sheet1.write(x,1, field.type)
sheet1.write(x,2, field.length)
for field2 in arcpy.ListFields(fc2):
z+=1
sheet1.write(z,5, field.name)
sheet1.write(z,6, field.type)
sheet1.write(z,7, field.length)
book.save(r"Z:" + "\\" + "Template_Geodatabase_FieldList2" + ".xls")
