HiI hope one of you can help me...In a for loop, my code selects in turn, a different set of points in a layer.It then runs PathAllocation for the selected points, as follows: if Distance_method == "model-cost":
## calculates the least cost distance to the nearest lineage point
## the result is written directly to lineage_dist_gridname
temp = arcpy.sa.PathAllocation(in_source_data="lin_lyr", in_cost_raster=maxent_model, out_distance_raster=lineage_dist_gridname)
lin_dist = arcpy.sa.Raster(lineage_dist_gridname)
layers_to_delete.append(lineage_dist_gridname)
The problem is that it always fails the second time the loop hits the PathAllocation line. The message is: python.exe has stopped working.This behavior is independent of the particular data selected on that iteration - I've tried changing the dataset, and the order, and it still fails on the second pass through the loop.The filename defined in lineage_dist_gridname is different on each iteration, so it is not a problem of overwriting the raster created on the first iteration.Has anyone hit a similar crash or has some idea about the cause?many thanksDan
