1. How to use this example : arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/DisplayInformation/ShowCallout at master · Esri/arcgis-runtime-s… without any qml code?
2. I am trying to implement this code in pure CPP but the calloutDataChanged() signal is not generated. My guess is that this is occuring because my Component (callout) is not binded to the QProperty.
What is the CPP equivalent for the following qml code in the ShowCallout.qml file???
Callout {
calloutData: showCalloutSample.calloutData // bind to the property that is exposed
accessoryButtonHidden: true
leaderPosition: leaderPositionEnum.Automatic
}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>3. Is there any reason which is causing the code to fail??
