I am trying to convert my web mapping application from legacy to AMD style. However, the error
message tells the "TypeError: dojo.promise is undefined". I have tried to see if the error could come from the object "tasks" and "params". However, I can not tell anything wrong. Could anyone show me the solution?
<!DOCTYPE html>
<html>
<head>
<link rel="stylesheet" type="text/css" href="style1.css">
<link rel="stylesheet" type="text/css" href="style3.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.11/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.11/esri/css/esri.css">
<title>NMED MAP AMD</title>
<script language="javascript" src="/JScript/universal_jsAPI.js"></script>
<style type="text/css">
.zoominIcon { background-image:url('Icons/Mag_plus2.svg');width:32px; height:31.1px;position:relative; right: 4px;bottom: 3px;background-size: contain;}
.zoomprev { background-image:url('Icons/Mag_minus2.svg'); width:32px; height:31.1px;position:relative; right: 4px;bottom: 3px;background-size: contain;}
.handIcon { background-image:url('Icons/HAND3.svg'); width:31.1px; height:31.1px;position:relative; right: 4px;bottom: 3.2px;background-size: contain;}
.pdfIcon { background-image:url('Icons/excel.png'); width:34px; height:36px;position:relative; left: -3px;top: 0px;}
.QueryInfo { background-image:url('Icons/Query.png'); width:32px; height:37px;position:relative; left: -2px;top: 3px;}
.FullExtent1{ background-image:url('Icons/globe_dark2.svg'); width:31px; height:31px;position:;position:relative; right: 4px;bottom: 2px;background-size: contain;}
.dijitButtonNode{width:55%;text-align: center; height: 120%}
.BibliographyIcon{ background-image:url('Icons/Book.svg'); type="image/svg+xml";width:75px; height:75px;position:absolute; left: -20px;top: -17px;background-size:contain;}
.UpdateIcon{ background-image:url('Icons/question.svg'); width:34px; height:34px;position:absolute; left: 1px;top: 2px;background-size: contain;}
.PrintIcon{ background-image:url('Icons/Printer_dark.svg'); width:31.1px; height:30.5px;position:absolute; left: 3px;top: 2.5px;background-size: contain;}
.WebmapData { background-image:url('Icons/DatFolder.svg'); width:34px; height:34px;position:relative; left: -5px;top: -5px;background-size: contain;}
</style>
<script src="https://js.arcgis.com/3.11/"></script>
<script>
var visible = [];
var legendLayers = {};
var coalminelayer;
var NMBGMRIndexlayer;
var id_connect, idParams;
require([
"dojo/Deferred",
"dojo/_base/connect",
"dojo/_base/array",
"dojo/promise/all",
"dojo/promise/Promise",
"dijit/form/HorizontalSlider",
"dijit/form/CheckBox",
"dojo/dom",
"dijit/registry",
"dojo",
"dojo/on",
"dojo/ready",
"dojo/parser",
"dojo/dom-construct",
"esri/tasks/IdentifyParameters",
"esri/tasks/IdentifyTask",
"esri/tasks/GeometryService",
"esri/Color",
"esri/dijit/Geocoder",
"esri/dijit/Popup",
"esri/dijit/PopupTemplate",
"esri/InfoTemplate",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/map",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol", "dojo/domReady!",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
], function(
Deferred,connect,array, all, Promise, HorizontalSlider, CheckBox, dom, registry, dojo, on, ready, parser, domConstruct, IdentifyParameters,IdentifyTask, GeometryService, Color ,Geocoder, Popup, PopupTemplate,
InfoTemplate, ArcGISDynamicMapServiceLayer, Map, SimpleFillSymbol, SimpleLineSymbol,BorderContainer,ContentPane)
ready(function(){
parser.parse();
esriConfig.defaults.io.proxyUrl = "http://maps.nmt.edu/DotNet/proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = false;
idParams = new esri.tasks.IdentifyParameters();
var popupOptions = {
'markerSymbol': new esri.symbol.SimpleMarkerSymbol('circle', 22, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([0, 0, 0, 0.25])),
'fillSymbol': new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5])),
'lineSymbol': new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2),
'marginLeft': '20',
'marginTop': '20'
//create a popup to replace the map's info window
//you'll need to include this dijit in the function
var popup = new esri.dijit.Popup(popupOptions,dojo.create("div"));
map = new Map("map", {
basemap:"topo",
center: [-106.9048, 34.0665],
zoom: 9,
allowKineticScrolling : false,
showAttribution: false,
wrapAround180: true,
sliderStyle: "large",
infoWindow:popup
var coalmineon = false
if(2==1){coalmineon=true;legDisplay('coalmineLeg');dijit.byId("coalmineChk").attr('checked',true)};
coalminelayer = initDynLayer("http://129.138.12.30:6080/arcgis/rest/services/CoalMineSJB/CoalMinsNM/MapServer","coalminelayer",false,0.8);
var NMBGMRIndexon=false
if(2==1){NMBGMRIndexon=true;legDisplay('NMBGMRIndexon');dijit.byId("NMBGMRIndexChk").attr('checked',true)};
NMBGMRIndexlayer = initDynLayer("http://129.138.12.30:6080/arcgis/rest/services/IndexMap/NMBGMR/MapServer","NMBGMRIndexlayer",false,0.8);
map.addLayers([coalminelayer,NMBGMRIndexlayer]);
dojo.connect(map, "onLoad", mapReady);
function mapReady(map) {
dojo.connect(map, "onClick", runIdentifies);
function initDynLayer(url,id,visibility,opac) {
var layer = new ArcGISDynamicMapServiceLayer(url, {id:id, visible:visibility, opacity:opac});
return layer;
function legDisplay(legID){
if(dojo.byId(legID).style.display=='none'){
dojo.byId(legID).style.display='block'
}else{
dojo.byId(legID).style.display='none'
// info window 111214
function runIdentifies(evt) {
identifyResults = [];
idPoint = evt.mapPoint;
var layers = dojo.map(map.layerIds, function (layerId) {
return map.getLayer(layerId);
layers = dojo.filter(layers, function (layer) {
if (layer.visibleLayers[0] !== -1) {
return layer.getImageUrl && layer.visible
}); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers
var tasks = dojo.map(layers, function (layer) {
return esri.tasks.IdentifyTask(layer.url);
}); //map each visible dynamic layer to a new identify task, using the layer url
var defTasks = dojo.map(tasks, function (task) {
return new dojo.Deferred();
}); //map each identify task to a new dojo.Deferred
var params = createIdentifyParams(layers, evt);
var promises = [];
for (i = 0; i < tasks.length; i++) {
promises.push(tasks.execute(params)); //Execute each task
var allPromises = new dojo.promise.all(promises);
allPromises.then(function (r) { showIdentifyResults(r, tasks); });
function showIdentifyResults(r, tasks) {
var results = [];
var taskUrls = [];
r = dojo.filter(r, function (result) {
return r[0];
for (i = 0; i < r.length; i++) {
results = results.concat(r);
for (j = 0; j < r.length; j++) {
taskUrls = taskUrls.concat(tasks.url);
results = dojo.map(results, function (result, index) {
var feature = result.feature;
var layerName = result.layerName;
var serviceUrl = taskUrls[index];
feature.attributes.layerName = result.layerName;
<!-- CoalMine Location 02172016-->
var content_CoalMineLocation =
"<b>CoalMine ID</b>: ${CoalMine_I}" +
"<br><b>Mine Name</b>: ${Mine_name}" +
"<br><b>Township</b>: ${Township}" +
"<br><b>Range</b>: ${Range}" +
"<br><b>Section</b>: ${Section}" +
"<br><b>Subsection</b>: ${Subsection}" +
"<br><b>Longitude</b>: ${Long_DD}" +
"<br><b>Latitude</b>: ${Lat_DD}" +
"<br><b>Location Notes</b>: ${LocationNo}"+
"<br><b >More Information</b>:<a target='_blank' href='http://127.0.0.1:5000/CoalMine/${CoalMine_I}' >Coal Mine Info</a>";
if(result.layerName=="GISData.CoakMinesNM") {
var template = new esri.dijit.PopupTemplate('<b>Coal Mine Location</b>', content_CoalMineLocation); }
var contentNMBGMR="<b>Quad Name</b>: ${NAME}" +
"<br><b>Map Title</b>: ${Map_Title}" +
"<br><b>Authors</b>: ${Authors}" +
"<br><b>Publication Year</b>: ${PubYear}" +
"<br><b>Series</b>: ${Series}" +
"<br><b>Series Number</b>: ${SeriesNo}" +
"<br><b >Publication Status</b>:<a target='_blank' href='${Web_URL}' >Geologic Map Information</a>";
if(result.layerName=="GISData.DBO.NMBGMR1") {
var template = new esri.dijit.PopupTemplate('<b>NMBGMR (pre-1993)</b>', contentNMBGMR);}
map.infoWindow.resize(400, 550);
feature.setInfoTemplate(template);
var resultGeometry = feature.geometry;
var resultType = resultGeometry.type;
return feature;
if (results.length === 0) {
map.infoWindow.clearFeatures();
} else {
map.infoWindow.setFeatures(results);
map.infoWindow.show(idPoint);
return results;
function createIdentifyParams(layers, evt) {
var identifyParamsList = [];
identifyParamsList.length = 0;
dojo.forEach(layers, function (layer) {
var idParams = new esri.tasks.IdentifyParameters();
idParams.width = map.width;
idParams.height = map.height;
idParams.geometry = evt.mapPoint;
idParams.mapExtent = map.extent;
idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
id_connect = dojo.connect(map,"onClick",runIdentifies);
var visLayers = layer.visibleLayers;
if (visLayers !== -1) {
idParams.layerIds = layer.visibleLayers;
} else {
idParams.layerIds = [];
idParams.tolerance = 3;
idParams.returnGeometry = true;
identifyParamsList.push(idParams);
return identifyParamsList;
</script>
</head>
<body class="tundra">
<!--[if IE 7]>
<style>
html, body {
margin: 0;
</style>
<![endif]-->
<div id="mainWindow"
