I'm writing an oracle function to convert a ST_MULTILINESTRING to a ST_LINESTRING.
To reach that goal, the function would convert the input object to WKT format, then perform some modifications to resulting string and finally create the ST_LINESTRING:
CREATE OR REPLACE FUNCTION MFICA_LINHA
(MULTILINHA IN SDE.ST_MULTILINESTRING)
RETURN SDE.ST_LINESTRING
IS
LINHA SDE.ST_LINESTRING;
BEGIN
SELECT SDE.ST_LINEFROMTEXT(replace(replace(replace(replace(SDE.ST_ASTEXT(MULTILINHA),'((','('),'),(',','),'))',')'),'MULTILINESTRING','LINESTRING'), 0)
INTO LINHA
FROM DUAL;
RETURN LINHA;
END;But it is getting the following error:
Error: PLS-00707: unsupported construct or internal error [2603]
Just to make sure that it youd work, I did:
SELECT SDE.ST_LINEFROMTEXT(LINE_TEXT, 0) LINE
FROM (
SELECT replace(replace(replace(replace(MLINE_TEXT, '((','('),'),(',','),'))',')'),'MULTILINESTRING','LINESTRING') LINE_TEXT
FROM (
SELECT SDE.ST_ASTEXT(MLINE) MLINE_TEXT
FROM (
SELECT SDE.ST_MLINEFROMTEXT('MULTILINESTRING ((0 0, 1 1),(1 1, 2 2))', 0) MLINE
FROM DUAL
);And I got a ST_SINGLELINE as expected.
In order to understand what would cause the creation funtion failure, I wrote a simpler version of the funciton:
IS
BEGIN
SELECT SDE.ST_LINEFROMTEXT('', 0)
INTO LINHA
FROM DUAL;
RETURN LINHA;
END;Since it successful compiled, tryied:
IS
BEGIN
SELECT SDE.ST_LINEFROMTEXT(SDE.ST_ASTEXT(MULTILINHA), 0)
INTO LINHA
FROM DUAL;
RETURN LINHA;
END;
But I got the PLS-00707 error.
Why does my function creation fails, and why can't I use both ST_ASTEXT and ST_LINEFROMSTRING nestled?
