Greetings to allI'm not getting access to the error messages with arcpy.GetMessages arcpy () and related functions. I'm really frustrated with this problem. For example, if I run on the Windows:arcpy.GetCount_management ("c
temp/solapes2.shp")
(where there is not solapes2.shp shape at the location indicated)I get the following error message:<class'arcgisscripting.ExecuteError'> Runtime error: ERROR 000732: Input Rows: c
temp/solapes2.shp the dataset does not exist or does not support
But if I execute, for example:import arcpy
try:
**** result = arcpy.GetCount_management ("c
temp/solapes2.shp")
except:
arcpy.GetMessageCount print ()
arcpy.GetMessages print (2)
I only get:0
(that is, a zero from GetMessageCount and a blank line from getMessages (2).Where is the problem? Am I wrong with the way errors are handled in the Python window? I tried several scripts that appear in the Help and their behavior is similar to that describe ....Thanks in advanceJesús de DiegoPd. I'm using ArcGIS 10.0, sp5. in a Windows 7 64 bits OS.
