Hi, I have a pile of 23 different rasters, on which I'm performing various calculations. One of them is a simple Maximization, using Cell Statistics, and one thing I'd like to see is a raster showing me which of the 23 layers contained the maximum value that was chosen. I'm finding this is pretty hard to do. In Arc 9.3, I solved this problem using a long string of Con() and Max() statements in the raster calculator, to assign an integer index value to each raster that was selected in the maximization. This is no longer possible in Arc 10 since Max() has been removed. I tried an approach in Python using the code below, but it does not really work. What I'm looking for is a way to return a raster with either index values from 1-23, or ideally the names of each input raster. Each name would be assigned to the cell if it was chosen as a maximum value. Hopefully this makes sense, I can elaborate if not. Any ideas here would be hugely helpful. Here's some sample code I've been playing with, but there has to be a simpler, more elegant solution - perhaps an obvious tool I'm missing?Thanks!opt2 = Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "blank",-9999, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "CottonLB" ,1, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "FodderLB" ,2, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "FruitsLB" ,3, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "GroundnutLB" ,4, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "JatrophaLB" ,5, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "MaizeLB" ,6, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "MilletLB" ,7, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "MiscanthusLB" ,8, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "NarcostimulantsLB" ,9, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "OilpalmLB" ,10, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "PulsesLB" ,11, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "RapeseedLB" ,12, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "RiceLB" ,13, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "RootsLB" ,14, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "SorghumLB" ,15, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "SoybeanLB" ,16, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "SugarbeetLB" ,17, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "SugarcaneLB" ,18, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "SunflowerLB" ,19, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "SwitchgrassLB" ,20, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "TubersLB" ,21, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "VegetablesLB" ,22, Con(CellStatistics(["CottonLB","FodderLB","FruitsLB","GroundnutLB","JatrophaLB","MaizeLB","MilletLB","MiscanthusLB","NarcostimulantsLB","OilpalmLB","PulsesLB","RapeseedLB","RiceLB","RootsLB","SorghumLB","SoybeanLB","SugarbeetLB","SugarcaneLB","SunflowerLB","SwitchgrassLB","TubersLB","VegetablesLB","WheatLB","blank"],"MAXIMUM","DATA") == "WheatLB" ,23,-9999))))))))))))))))))))))))
