I don't want any pop-ups on my maps in the ArcGIS StoryMaps Sidecar, so I've un-enabled them on all my layers on my Webmap (right picture below). However, when I click on the layer in the Sidecar, a pop-up still opens! What am I doing wrong?
Hi Kate -- Sorry you ran into this. We are aware of this issue and plan to address it in our upcoming release in a few weeks.
Sounds good. Thanks, Owen!
I still see this as an issue, Owen. Is there plans for a future release fixing this?
Hello Kate -- We fixed the issue we were aware of in our April release. Can you share the map you are having trouble with? Perhaps there is another similar issue or case that we're not aware of.
Hi Owen. I cannot share the map yet. We're hoping to make it public in a month or so, but for now, here's what it looks like still (screenshots taken today). Bug is clearly not fixed.
Hi Owen,
I have a question in reverse: how do I turn on popup in Sidecar? I have popup enabled in Map Viewer, but it is not loaded in Sidecar. I am using StoryMap in Enterprise Portal.
Thanks!
@Boyang_Wang -- Pop-ups should be enabled in your story on any layers where they are enabled in the map. If you are seeing something different on you Enterprise portal, please contact Esri Support and they will be able to help you troubleshoot further.
I figured out that, if a set the symbology of a layer to no color in Map Viewer, the popup will still be enabled in Map Viewer, but not in StoryMaps Sidecar. I changed the symbology and this is now resolved. Perhaps this has something to do with the classic Map Viewer in my Enterprise Portal vs the new Map Viewer in StoryMaps?
Boyang
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
