I need to change a Data Frame's Unit Display which is currently Degrees Decimal Minutes.. I open View | Data Frame and then in the dialog under Units Display, select Decimal Degrees from the drop-down menu.and click Apply. Nothing happens. When I click on OK to go back to the Data Frame the Unit's Display is unchanged, still showing Degrees Decimal Minutes. How to fix this please? Thanks very much.
