Just to save someone some linking in the future. I pulled the relevant code:
require([ "esri/Map", "esri/views/MapView", "esri/layers/support/LOD", "dojo/domReady!"], function (Map, MapView, LOD) { var lods = []; var tilesize = 256; var earthCircumference = 40075016.685568; var halfEarthCircumference = halfEarthCircumference * 0.5; var inchesPerMeter = 39.37; var initialResolution = earthCircumference / tilesize; for (var zoom = 0; zoom <= 27; zoom++) { var resolution = initialResolution / Math.pow(2, zoom); var scale = resolution * 96 * inchesPerMeter; lods.push(new LOD({ level: zoom, scale: scale, resolution: resolution })); } var map = new Map({ basemap: "streets" }); var view = new MapView({ container: "viewDiv", map: map, zoom: 18, center: [-104.991531, 39.742043], constraints: { lods: lods } });});
var c = new esri.geometry.Point(2473044, 7636297, new esri.SpatialReference({ wkid: 2953 })); var lods = [ {"level" : 0, "scale" : 3000000, "resolution" : 793.75158750317507}, {"level" : 1, "scale" : 2000000, "resolution" : 529.16772500211675}, {"level" : 2, "scale" : 1000000, "resolution" : 264.58386250105838}, {"level" : 3, "scale" : 500000, "resolution" : 132.29193125052919}, {"level" : 4, "scale" : 250000, "resolution" : 66.145965625264594}, {"level" : 5, "scale" : 125000, "resolution" : 33.072982812632297}, {"level" : 6, "scale" : 50000, "resolution" : 13.229193125052918}, {"level" : 7, "scale" : 30000, "resolution" : 7.9375158750317505}, {"level" : 8, "scale" : 12500, "resolution" : 3.3072982812632294}, {"level" : 9, "scale" : 5000, "resolution" : 1.3229193125052918}, {"level" :10, "scale" : 2500, "resolution" : 0.66145965625264591}, {"level" :11, "scale" : 1000, "resolution" : 0.26458386250105836}, {"level" :12, "scale" : 500, "resolution" : 0.13229193125052918}, {"level" :13, "scale" : 250, "resolution" : 0.066145965625264591}, {"level" :14, "scale" : 100, "resolution" : 0.026458386250105836}, ]; map = new esri.Map("map", { basemap: standard_basemap_basemap, center: c, zoom: 6, slider: false, logo: false, spatialReference: new esri.SpatialReference({ wkid: 2953 }), lods: lods });
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
