I have some code that will geocode a point and display it on the map. I would like to label the point with the address.
I create a label graphic using the coordinates of the point and the address, add graphic to the graphics layer, but it does not display on the map.
Not sure what I am missing.
Here is the section of code:
fromlocator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"location-to-address-complete"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//mapMain.graphics.remove(fGraphic);</SPAN>
<SPAN class="keyword token">var</SPAN> attr<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> fromAddress <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">alert</SPAN><SPAN class="punctuation token">(</SPAN>fromAddress<SPAN class="punctuation token">.</SPAN>Address <SPAN class="operator token">+</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>City <SPAN class="operator token">+</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>Region<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>Postal<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>fromAddress<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fromAddr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>Address <SPAN class="operator token">+</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>City <SPAN class="operator token">+</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>Region<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> fromAddress<SPAN class="punctuation token">.</SPAN>Postal<SPAN class="punctuation token">;</SPAN>
fPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
attr <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"Address"</SPAN><SPAN class="punctuation token">:</SPAN> fromAddress
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create point graphic from geocoded point, add to graphiclayer, add layer to map.</SPAN>
fGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>fPoint<SPAN class="punctuation token">,</SPAN> fromGeocodeSymbol<SPAN class="punctuation token">,</SPAN> attr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>fGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>graphicsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a text symbol to define the style of labels</SPAN>
<SPAN class="keyword token">var</SPAN> textColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#666"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> textLabel <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TextSymbol</SPAN><SPAN class="punctuation token">(</SPAN>fromAddress<SPAN class="punctuation token">)</SPAN>
textLabel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN>textColor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
textLabel<SPAN class="punctuation token">.</SPAN>font<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"14pt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
textLabel<SPAN class="punctuation token">.</SPAN>font<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setFamily</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"arial"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
textLabelRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>textLabel<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//create label to add to graphic layer</SPAN>
<SPAN class="keyword token">var</SPAN> testlabel <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>fPoint<SPAN class="punctuation token">,</SPAN> textLabel<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//add label to graphics layer</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>testlabel<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">zoomToAddresses</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">getZone</SPAN><SPAN class="punctuation token">(</SPAN>fPoint<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"from"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
