I am an trying to use map.on("load") but when I put it into my code, a blank map shows. Without it, the map displays just fine.
I must be missing something simple here, but I can't find the issue.
Thanks for any assistance in resolving this.
Mele
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Search <SPAN class="keyword token">with</SPAN> Suggestion Template<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.19%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">https://js.arcgis.com/3.19/dijit/themes/claro/claro.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.19%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.19/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#map <SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">90</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">90</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
#search <SPAN class="punctuation token">{</SPAN>
display<SPAN class="punctuation token">:</SPAN> block<SPAN class="punctuation token">;</SPAN>
position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN>
z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN>
top<SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
left<SPAN class="punctuation token">:</SPAN> 74px<SPAN class="punctuation token">;</SPAN>
#LocateButton <SPAN class="punctuation token">{</SPAN>
top<SPAN class="punctuation token">:</SPAN> 95px<SPAN class="punctuation token">;</SPAN>
left<SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.19%2F" target="_blank">https://js.arcgis.com/3.19/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/locator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Search"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ArcGISTiledMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/dijit/LocateButton"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/GeometryService"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/IdentifyTask"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/IdentifyParameters"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> Locator<SPAN class="punctuation token">,</SPAN> Search<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN>InfoTemplate<SPAN class="punctuation token">,</SPAN>Extent<SPAN class="punctuation token">,</SPAN>ArcGISTiledMapServiceLayer<SPAN class="punctuation token">,</SPAN>LocateButton<SPAN class="punctuation token">,</SPAN> array<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> GeometryService<SPAN class="punctuation token">,</SPAN> IdentifyTask<SPAN class="punctuation token">,</SPAN> IdentifyParameters<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> customBasemap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISTiledMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaps%2Farcgis%2Frest%2Fservices%2FBase_Map%2FMapServer" target="_blank">https://maps/arcgis/rest/services/Base_Map/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
extent<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>xmin<SPAN class="punctuation token">:</SPAN><SPAN class="number token">675912</SPAN><SPAN class="punctuation token">,</SPAN>ymin<SPAN class="punctuation token">:</SPAN><SPAN class="number token">886288</SPAN><SPAN class="punctuation token">,</SPAN>xmax<SPAN class="punctuation token">:</SPAN><SPAN class="number token">755209</SPAN><SPAN class="punctuation token">,</SPAN>ymax<SPAN class="punctuation token">:</SPAN><SPAN class="number token">1060473</SPAN><SPAN class="punctuation token">,</SPAN>spatialReference<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">2223</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token function">alert</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"loaded"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>customBasemap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
esriConfig<SPAN class="punctuation token">.</SPAN>defaults<SPAN class="punctuation token">.</SPAN>geometryService <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GeometryService</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaps%2Farcgis%2Frest%2Fservices%2FUtilities%2FGeometry%2FGeometryServer" target="_blank">https://maps/arcgis/rest/services/Utilities/Geometry/GeometryServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> lyrFields<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> URL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaps%2Farcgis%2Frest%2Fservices%2FParcel_Information%2FMapServer%2F25" target="_blank">https://maps/arcgis/rest/services/Parcel_Information/MapServer/25</A><SPAN>"</SPAN></SPAN>
fl <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>URL<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> ParcelsURL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaps%2Farcgis%2Frest%2Fservices%2FParcel_Information%2FMapServer" target="_blank">https://maps/arcgis/rest/services/Parcel_Information/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
geoLocate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LocateButton</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> map
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LocateButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
geoLocate<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> search <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
sources<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
featureLayer<SPAN class="punctuation token">:</SPAN> fl<SPAN class="punctuation token">,</SPAN>
searchFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"fulladdr"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
displayField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fulladdr"</SPAN><SPAN class="punctuation token">,</SPAN>
exactMatch<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"parcel_code"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fulladdr"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"lot_number"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"subdiv_name"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Parcels"</SPAN><SPAN class="punctuation token">,</SPAN>
placeholder<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"3629 N Drinkwater"</SPAN><SPAN class="punctuation token">,</SPAN>
maxResults<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
maxSuggestions<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//Create an InfoTemplate and include three fields</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Parcels"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Address: ${fulladdr}</br>APN: ${parcel_code}</br>Lot Number: ${lot_number}</br>Subdivision: ${subdiv_name}"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
enableSuggestions<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
enableInfoWindow<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
minCharacters<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
allPlaceholder<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Find Address"</SPAN><SPAN class="punctuation token">,</SPAN>
activeSourceIndex<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"all"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"search"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
search<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> selectionMade <SPAN class="operator token">=</SPAN> search<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"select-result"</SPAN><SPAN class="punctuation token">,</SPAN> selectionHandler<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">selectionHandler</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> resultItems <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> featureAttributes <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>result<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> attr <SPAN class="keyword token">in</SPAN> featureAttributes<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
resultItems<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"<b>"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="token function">getFldAlias</SPAN><SPAN class="punctuation token">(</SPAN>attr<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">":</b> "</SPAN> <SPAN class="operator token">+</SPAN> featureAttributes<SPAN class="punctuation token">[</SPAN>attr<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"<br>"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"info"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> resultItems<SPAN class="punctuation token">.</SPAN><SPAN class="token function">join</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getFldAlias</SPAN><SPAN class="punctuation token">(</SPAN>fieldName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> retVal <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>fl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">some</SPAN><SPAN class="punctuation token">(</SPAN>fl<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">===</SPAN> fieldName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
retVal <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>alias<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> retVal<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"LocateButton"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"search"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"info"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"margin: 5px; padding: 5px; background-color: #eeeeee;"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
