Specifying opacity is causing the layer to disappear in IE. We'll look into this. As a workaround, can you only specify opacity if you're in a non-IE browser? Something like ... if ( ! dojo.isIE ) { milRadar.setOpacity(0.5); }
I'm seeing a similar issue with IE browsers where the scalebar, zoom slider and popup window opacity is also changing with setOpacity() on any map layer. Is this related to the same issue? I am using version 2.5. If I go back to a map using 2.2, I do not see this problem.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Topographic Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{ padding: 20px 20px; } #map{ padding:0; } </style> <script type="text/javascript">var djConfig = {parseOnLoad: true};</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); /* require for map image layer */ dojo.require("esri.layers.MapImageLayer"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-97,"ymin":34,"xmax":-88,"ymax":41,"spatialReference":{"wkid":4326}}); map = new esri.Map("map",{extent:initExtent}); //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://maps.modot.mo.gov/ArcGIS/rest/services/baseMap/baseMapCombined/MapServer"); map.addLayer(basemap); /* mi layer code start */ var milRadar = new esri.layers.MapImageLayer({ id: "NwsRadar", opacity: 0.6, visible: true }); var radarMapImage = new esri.layers.MapImage({ extent: { xmin: -100.164199191007, ymin: 32.421437253085, xmax: -86.0629362487793, ymax: 44.3767001897639, spatialReference: { wkid: 4326} }, href: "http://maps.modot.mo.gov/timconfig/NWS_0.png" }); milRadar.addImage(radarMapImage); map.addLayer(milRadar); /* mi layer code end */ dojo.connect(map, 'onLoad', function(theMap) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> </div> </div> </body> </html>
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
