arcpy.FieldMapping problem
Hi there,
I'm new to scripting and still struggling to figure out how everything works. When a call the FieldMappings function in the script the following error occurs: <type 'exceptions.AttributeError'>: Object: Tool or environment <s> not found
Failed to execute (runAccuracy). I know for a fact it is the at the exact moment when I call the function when the script fails. I'm doing exactly the same than a few examples I found on the internet on setting up FieldMappings for python scripts. The code is provided below:
import arcgisscripting, os, sys, string, math, traceback, shutil, subprocess
from time import localtime, strftime
import arcpy
import os
from arcpy import env
from arcpy.sa import *
arcpy = arcgisscripting.create(10.0)
arcpy.overwriteoutput = 1
arcpy.SetProduct("ArcInfo")
class GetOutOfLoop( Exception 😞
pass
# Version
version = 1
# Directories
fportion_loc = "C:/Divan/FPortion/FPortion/"
points_loc = "C:/Divan/FPortion/Points/"
temp_loc = "c:/Divan/FPortion/temp/"
export_loc = "C:/Divan/FPortion/Exported/"
ws = temp_loc
env.workspace = ws
# Checks the extension of a given file
def checkExtension(fileName, extension):
length = len(fileName)
# If the string length is less than 3 character, it can't be a .shp or .tif file
if length < 3:
return -1
else:
lowercase = fileName.lower()
found = lowercase.find(extension, length - 4, length)
if found == -1:
return -1
else:
return 0
try:
# List all files
fportionFiles = os.listdir(fportion_loc)
pointsFiles = os.listdir(points_loc)
# Loops through all the fportion_loc files
for fportionfile in fportionFiles:
if checkExtension(fportionfile, ".shp") != -1:
index = fportionfile.find("_") # Finds the index of the '_' character
prefix = fportionfile[:index] # Stores the prefix of the file
arcpy.AddMessage("Zone(polygon) shapefile found: " + fportionfile)
arcpy.MakeFeatureLayer(fportion_loc + fportionfile, fportionfile + "_ref_fportion")
cnt = 0
# Loops through all the dem_loc files
for pointsFile in pointsFiles:
points_lowercase = string.lower(pointsFile)
if checkExtension(points_lowercase, ".shp") != -1:
arcpy.AddMessage("Point shapefile found: " + pointsFile)
arcpy.MakeFeatureLayer(points_loc + pointsFile, pointsFile + "_tmp")
arcpy.AddMessage("Creating fieldmappings...")
fieldmappings = arcpy.FieldMappings() # The error occurs when I call this function
arcpy.AddMessage(" bla!!!!")
#fieldmappings.addTable(fportion_loc + fportionfile)
#fieldmappings.addTable(points_loc + pointsFile)
#fieldIndex = fieldmappings.findFieldMapIndex("RASTERVALU")
#fieldMap = fieldmappings.getFieldMap(fieldIndex)
#fieldProperties = fieldmap.outputField
#field.name = "mean_elev"
#field.aliasName = "mean_elev"
#fieldMap.outputField = field
#fieldMap.mergeRule = "mean"
#fieldmappings.replaceFieldMap(fieldIndex, fieldMap)
#arcpy.AddMessage("Executing spatial join...")
#arcpy.SpatialJoin_analysis(fportionfile + "_ref_fportion", pointsFile + "_tmp", export_loc + prefix + "_done.shp", "JOIN_ONE_TO_MANY", "KEEP_ALL", fieldmappings, "CONTAINS")
except GetOutOfLoop:
pass
The code that has been commented out to determine where the error occurs.
Thanks in advance
