Hi. Help from FAQ says:
"To create your Shortlist using point data in an existing web map, first go to ArcGIS Online and open that web map. Then share it as a web application and choose Story Map Shortlist from the application gallery. The Shortlist builder will open and prompt you to select the point data you want to use. The Shortlist builder automatically copies your imported places into a new web map."
Note: If the Story Map Shortlist isn't present in the application gallery when you share a web map, you are either using Portal for ArcGIS, which doesn't contain our beta apps like Shortlist, or you are using an ArcGIS Online Organization in which the application gallery has been customized..."
I am using my personal ArcGIS Online account and I still can not see Story Map Shortlist in the application gallery.
Can you please hepl me with the problém.
Thank you.
Paldo
