def getParameterInfo(self):
def getParameterInfo(self): ### Define parameter definitions param0 = arcpy.Parameter( displayName="Input Feature Class Location", name="edit_fc", datatype="Feature Class", parameterType="Optional", direction="Input", multiValue=True) param0.filter.list = ["Polygon", "Polyline", "Point"] param1 = arcpy.Parameter( displayName="OID Query Expression", name="oid_query", datatype="SQL Expression", parameterType="Optional", direction="Input") param1.parameterDependencies = [param0.name] param2 = arcpy.Parameter( displayName="Workflow", name="wf_name", datatype="String", parameterType="Optional", direction="Input") params = [param0, param1, param2] return params
The Reviewer batch job results are written to the specified session (indicated by Session) in the Reviewer Workspace.A summary of the batch job is displayed in the Results window.The output parameter for this tool is a table view of one row of the REVBATCHRUNTABLE table in the Reviewer Workspace. The row represents the record created when the batch job is executed.
# execute the batch job res = arcpy.ExecuteReviewerBatchJob_Reviewer(rev_workspace,session,batch_job_file,prod_workspace) # get the output table view from the result object tbl = res.getOutput(0)
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
