I am trying to convert my old ArcGIS 9.3 (VBA) code to ArcGIS 10 using Visual Basic 2008 Express Edition. So far I have sucessfully created an pop-up window that displays the attributes of a selected feature in text boxes on the form. However, I want to create a button that allows users to save any changes they make to the attributes in the user form. Below is the code I have thus far for the On_Click event to update the attributes. The error I'm getting is on "IEditor.EditState <> esriStateEditing Then" IT says reference to non-shared member requires an object referencePrivate Sub cmdUpdate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdUpdate.Click
Dim pMxDoc As IMxDocument
pMxDoc = My.ArcMap.Document
Dim pMap As IMap
pMap = pMxDoc.FocusMap
Dim pFLayer As IFeatureSelection
Dim Count As Integer
For Count = 0 To pMap.LayerCount - 1
'Get the Transportation Improvement Line Layer from the Map
If pMap.Layer(Count).Name = "TransportationImprovementProjects_Lines" Then
pFLayer = pMap.Layer(Count)
Dim pFCursor As IFeatureCursor = Nothing
pFLayer.SelectionSet.Search(Nothing, False, pFCursor)
Dim pF As IFeature
pF = pFCursor.NextFeature
End If
'Get Dataset from FeatureLayer
Dim pEditDataset As IDataset
pEditDataset = pFLayer
'If not editing, start editing dataset's Workspace
If IEditor.EditState <> esriStateEditing Then
Editor.StartEditing(pEditDataset.Workspace)
End If
'Initialize first (only) feature
Dim pFeat As IFeature
pFeat = pFLayer.NextFeature
'Update attributes with user input
pFeat.Value(pFeat.Fields.FindField("YEAR")) = txtPrjYear.Text
pFeat.Value(pFeat.Fields.FindField("PROJECTYPE")) = txtPrjType.Text
pFeat.Value(pFeat.Fields.FindField("LOCATION")) = txtLocation.Text
pFeat.Value(pFeat.Fields.FindField("AGENCY")) = txtAgency.Text
pFeat.Value(pFeat.Fields.FindField("DESCRIPTION")) = txtDescrip.Text
pFeat.Value(pFeat.Fields.FindField("COST")) = txtCost.Text
pFeat.Value(pFeat.Fields.FindField("DATEEDITED")) = txtDate.Text
pFeat.Value(pFeat.Fields.FindField("USEREDITED")) = txtUser.Text
'Store changes to feature
pFeat.Store()
'Stop editing and save edits
Editor.StopEditing(True)
'Refresh map
pMxDoc.ActiveView.Refresh()
'Close form
Me.Close()
Next Count
End Sub
