Greetings,
I am using Edit rivers and waterbodies sample with my polyline feature layer(m enabled), the problem is i cant edit the vertices or move the polyline i can only change the attributes of the feature. if i use the same sample which is not m enabled the sample is working fine. Also i noted that if i double click the feature sometimes it disappears, I have to pan the map or zoom in/out to see the feature again is it a bug?
Regards,
Haider
