I would like to display text in a pop-up that is based on a dictionary. Can i write an arcade if statement that compares the attribute to the dictionary "value", then return the dictionary "label" in the pop-up? I am not very familiar with javascript and unsure how to test for the attribure value equal to the dictionary "value". for example, I have this so far:
var dict = [{label: "N-1", value: "001"},
{label: "N-2", value: "002"},
{label: "N-4", value: "004"},
{label: "N-5", value: "005"}],
for(var k in dic){
var kValue = dic.value;
var kLabel = dic.label;
var routeid = $feature.FIRST_RouteID;
var popup = IIF(routeid == kValue ,kLabel,"NoVal");
return popup;
this is returning "N-1" when i test the result, but does not work when clicking on a feature. It must not be looping through the dictionary like I think it should?
I solved this by changing my array variable and using the When function like so:
var routeid = $feature["FIRST_RouteID"];
var routeLabel = When(
routeid == "001","N-1",
routeid == "002","N-2",
routeid == "004","N-4",
routeid == "S93A","S93A",
'n/a')
return routeLabel
Chris
