Hi
Please review the following code.
I have a problem that i want to remove previous table when user click new value (it means hide previous table and show new table of new value). i have added image to understand problem.
Robert Scheitlin, GISP Rene Rubalcava Kelly Hutchins
<SPAN class="keyword token">import</SPAN> React <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'react'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">import</SPAN> <SPAN class="punctuation token">{</SPAN> loadModules <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'react-arcgis'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">import</SPAN> Axios <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'axios'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">export</SPAN> <SPAN class="keyword token">default</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">QueryODB</SPAN> <SPAN class="keyword token">extends</SPAN> <SPAN class="token class-name">React<SPAN class="punctuation token">.</SPAN>Component</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">constructor</SPAN><SPAN class="punctuation token">(</SPAN>props<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">super</SPAN><SPAN class="punctuation token">(</SPAN>props<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>state <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
ODB<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
server<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="token function">componentDidMount</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>props<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>props<SPAN class="punctuation token">.</SPAN>view<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">loadModules</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/widgets/Expand'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/geometryEngine"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>Query<SPAN class="punctuation token">,</SPAN> QueryTask<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> Expand<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> geometryEngine<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> Request<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">/* view.ui.add(
new Expand({
view:view,
content: document.getElementById('attribute'),
group: 'bottom-right',
expanded: false
"top-left"
) */</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"infoDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
group<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">,</SPAN>
expanded<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
expandIconClass<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fas fa-object-group"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="string token">"top-right"</SPAN>
<SPAN class="keyword token">let</SPAN> OdbfromPOP <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'odb-type'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> ODBRenderer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleRenderer()</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-marker"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleMarkerSymbol()</SPAN>
size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
const FiberRenderer = {
type: "simple", // autocasts as new SimpleRenderer()
symbol: {
type: "simple-line", // autocasts as new SimpleLineSymbol()
width: "2px",
color: [0, 255, 255],
outline: null
*/</SPAN>
<SPAN class="comment token">// *********** ODB Query ***************</SPAN>
<SPAN class="keyword token">let</SPAN> odburl <SPAN class="operator token">=</SPAN> <SPAN class="string token">"http://172.16.6.64:6080/arcgis/rest/services/KarachiSDE/FeatureServer/1"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> ODB <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> odburl<SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'ODB/DC'</SPAN><SPAN class="punctuation token">,</SPAN>
renderer<SPAN class="punctuation token">:</SPAN> ODBRenderer<SPAN class="punctuation token">,</SPAN>
listMode<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"hide"</SPAN><SPAN class="punctuation token">,</SPAN>
popupTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ODB/DC"</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Name"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Name"</SPAN><SPAN class="punctuation token">,</SPAN>
format<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
digitSeparator<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
places<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Splitter"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Splitter"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ID"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ID"</SPAN><SPAN class="punctuation token">,</SPAN>
digitSeparator<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"City"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"City"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>ODB<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> resultsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>resultsLayer<SPAN class="punctuation token">)</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> ODB<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> ODB<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> ODB<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getValues<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getUniqueValues<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>addToSelect<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getValues</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> values <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">,</SPAN> index<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>POP<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> values<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getUniqueValues</SPAN><SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> uniqueValues <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>
<SPAN class="punctuation token">(</SPAN>uniqueValues<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token"><</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">||</SPAN> uniqueValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">===</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN>
item <SPAN class="operator token">!==</SPAN> <SPAN class="string token">""</SPAN>
uniqueValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> uniqueValues<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addToSelect</SPAN><SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">sort</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">,</SPAN> index<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> option <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"option"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
option<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">=</SPAN> value<SPAN class="punctuation token">;</SPAN>
OdbfromPOP<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>option<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">setWellsDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN>OdbfromPOP<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setWellsDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN>newValue<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
ODB<SPAN class="punctuation token">.</SPAN>definitionExpression <SPAN class="operator token">=</SPAN> <SPAN class="string token">"POP = '"</SPAN> <SPAN class="operator token">+</SPAN> newValue <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> queryodb <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
returnGeometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Name"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
where<SPAN class="punctuation token">:</SPAN> ODB<SPAN class="punctuation token">.</SPAN>definitionExpression
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">executeForCount</SPAN><SPAN class="punctuation token">(</SPAN>queryodb<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'results'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">" ODBs are "</SPAN> <SPAN class="operator token">+</SPAN> results<SPAN class="punctuation token">;</SPAN>
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>queryodb<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> attribute <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"attribute"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> table <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"table"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
table<SPAN class="punctuation token">.</SPAN>border <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> header <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"tr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
table<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>header<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
response<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>element <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> column <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"th"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
column<SPAN class="punctuation token">.</SPAN>textContent <SPAN class="operator token">=</SPAN> element<SPAN class="punctuation token">.</SPAN>alias<SPAN class="punctuation token">;</SPAN>
header<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>column<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//alert(response.data.fields<I>.alias);</I></SPAN>
response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>res <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// console.log(response.features<J>)</J></SPAN>
<SPAN class="keyword token">var</SPAN> row <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"tr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
table<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
response<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>response <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//console.log(response.fields<I>) </I></SPAN>
<SPAN class="keyword token">var</SPAN> columns <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"td"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
columns<SPAN class="punctuation token">.</SPAN>textContent <SPAN class="operator token">=</SPAN> res<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>response<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
row<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>columns<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">///console.log(feature.attributes[field.name])</SPAN>
attribute<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set a new definitionExpression on the wells layer</SPAN>
<SPAN class="comment token">// and create a new buffer around the new wells</SPAN>
OdbfromPOP<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"change"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> btn <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'query-button'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
btn<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> type <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'pop'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> type
<SPAN class="token function">setWellsDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN>type<SPAN class="punctuation token">)</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'attribute'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-left"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">render</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>
<SPAN class="operator token"><</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"infoDiv"</SPAN><SPAN class="operator token">></SPAN>
SELECT <SPAN class="operator token">*</SPAN> FROM DC_ODB WHERE<SPAN class="punctuation token">:</SPAN>
<SPAN class="operator token"><</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>strong<SPAN class="operator token">></SPAN>POP <SPAN class="operator token">=</SPAN> <SPAN class="operator token"><</SPAN>span id<SPAN class="operator token">=</SPAN><SPAN class="string token">"pop"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>strong<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>select id<SPAN class="operator token">=</SPAN><SPAN class="string token">"odb-type"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>option value <SPAN class="operator token">=</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>Unselect ODB<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>select<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>br <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"query-button"</SPAN><SPAN class="operator token">></SPAN>Click to query<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>br <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"results"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"attribute"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> I select POP ID(21001) to show it's record on map as a table. it's working.
when i select second POP ID (21004), the new table opens whereas old table does not disappear.
