Hi everyone!
I need your help again... So I have this code now, which takes all columns from database I need. The X and the Y coordinates fields isn`t at the database. How do I add two new columns only in exporting CSV file ?
Thanks for any help!
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> csv
fc <SPAN class="operator token">=</SPAN> r"<SPAN class="comment token">#"</SPAN>
out_csv <SPAN class="operator token">=</SPAN> r"<SPAN class="comment token">#.csv"</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>"<SPAN class="comment token">#", "#"]</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">tableToCSV</SPAN><SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> out_csv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
fld_list <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN>
fld_names <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>fld<SPAN class="punctuation token">.</SPAN>name <SPAN class="keyword token">for</SPAN> fld <SPAN class="keyword token">in</SPAN> fld_list<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>out_csv<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> csv_file<SPAN class="punctuation token">:</SPAN>
writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>csv_file<SPAN class="punctuation token">,</SPAN> delimiter<SPAN class="operator token">=</SPAN><SPAN class="string token">';'</SPAN><SPAN class="punctuation token">,</SPAN> lineterminator<SPAN class="operator token">=</SPAN><SPAN class="string token">'\n'</SPAN><SPAN class="punctuation token">)</SPAN>
writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN>fields<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> fields<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> out_csv
csv_file<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
tableToCSV<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> out_csv<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
