Has anyone figured out a slick way to convert a table with X and Y coordinate values, along with other attributes, to a featureclass in arcpy outside of ArcGIS Desktop like in Spyder or Pycharm?
Roland Vigor from the USGS documented a nice way of converting a pandas dataframe to an arcgis table. I'd like to do something like that only one step further to make a featureclass.
I can use the Make XY Event Layer tool and display the points in Arc and then export those values to a feature class. However, I have dozens of files I need to filter in pandas and then convert to feature classes. So doing it outside of ArcMap using arcpy would be the best process.
I've seen a lot of requests for such a process but have yet to find something that works outside of ArcMap. Any help is much appreciated.
Cheers!
-Adam
