Hi,I'm trying to write my first DOJO class and re-use it within a very simple application, however I can't figure out why the `declare` method in DOJO is not defined? Here is my DOJO class code in a separate file: mapManager.js// CLASS// mapManagerrequire(['dojo/_base/declare'], function(declare){ delcare("mapManager", null, { sourceMapNode: null, maxZoomResolution: 10, constructor: function(params){ this.params = params || {}; // Returns a object literal if undefined // specifiy class defaults this.sourceMapNode = params.sourceMapNode; this.maxZoomResolution = params.maxZoomResolution; // Hook up map movement events alert("Hooking up map move events!"); } }); });Here is the index page that sets up the ESRI SDK, includes my special class and attempts to instantiate it.<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Simple Map</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } body { background-color:#FFF; overflow:hidden; font-family:"Trebuchet MS"; } </style> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script> <script src="script/class/mapManager.js"></script> <script> dojo.require("mapManager"); function init() { var parameters = { sourceMapNode : "map", mapZoomResolution: 12 }; // Give map to map manager var mapManager = new omega.mapManager(parameters); } dojo.ready(init); </script> </head> <body class="claro"> <div id="map"></div> </body> </html> In Firebug the first error I see is:---------------------------------------------ReferenceError: delcare is not defined[Break On This Error] delcare("mapManager", null,---------------------------------------------The second error I see is a 404 error:---------------------------------------------"NetworkError: 404 Not Found - http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/mapManager.js"---------------------------------------------Two questions:1. What am I doing wrong? I have followed tutorials on DOJO's website and this should be working. Of course I have missed something important, I'm sure.2. Why is custom class mapManager.js assumed to be a part of the DOJO library provided by ESRI? The second error indicates that the page "thinks" mapManager.js is part of the ESRI library when infact it's available locally.Thanks
