geo-processing errors in REST
Hi
Using ArcGIS 9.3.1 SP 2, I've written a python script which I've published to server. It works fine, but I've got an issue with error messages.
I've got a check in my script which detects bad input parameters. If the data isn't any good then I throw an error with gp.AddError.
This works fine if I consume the tool using ArcCatalog (I get a helpful message which was created by my gp.AddError) , but when consuming the tool through the rest interface, if you end up running the gp.AddError section, the server returns HTTP 500:
"error" :
"code" : 500,
"message" : "Error Executing Task",
"details" : []
What's happened to my helpful error message?
However I change the gp.AddError to gp.AddWarning, the JSON contains the kind of information I'm looking for:
"results" : [
"paramName" : "IDP",
"dataType" : "GPString",
"value" : ""
"messages" : [
{"type" : "esriJobMessageTypeInformative", "description" : "Executing (Add Something): AddSomething 99 \"Record Set\" # # # #"},
{"type" : "esriJobMessageTypeInformative", "description" : "Start Time: Mon Dec 06 13:36:15 2010"},
{"type" : "esriJobMessageTypeInformative", "description" : "Running script AddSomething..."},
{"type" : "esriJobMessageTypeWarning", "description" : "Here is a warning wanting to be an error!"},
{"type" : "esriJobMessageTypeInformative", "description" : "Completed script AddSomething..."},
{"type" : "esriJobMessageTypeInformative", "description" : "Executed (Add Something) successfully."},
{"type" : "esriJobMessageTypeInformative", "description" : "End Time: Mon Dec 06 13:36:15 2010 (Elapsed Time: 0.00 seconds)"}
Why can't I have this kind of message when I use gp.AddError? I'd quite like to be able to write a user friendly application which gives meaningful feedback when errors happen. Is there a configuration setting to adjust this?
