I want to reproject my FeatureLayer with client side Point features (wkid: 31468) into my streets basemap (default wkid: 4326).
How can I do this. See me code below, there is one point in "features". There will be several thousand points in future to be displayed.
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"streets"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">10.757158</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">48.181567</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4408681.069</SPAN><SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5338984.143</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> lyr <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
fields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"oid"</SPAN>
objectIdField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
geometryType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"point"</SPAN><SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">31468</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
source<SPAN class="punctuation token">:</SPAN> features<SPAN class="punctuation token">,</SPAN>
renderer<SPAN class="punctuation token">:</SPAN> baumRenderer <SPAN class="comment token">//custom renderer</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Thank you very much for your help.
Michael
