Do you have a code sample that you would care to share? Thanks!
while(feature !=null) { /* * reproject feature to web mercator */ feature.project(webMercator); // webMercator is a SR defined as class property if (getGeometryType()=="esriGeometryPoint") geometryStr=ServerUtilities.getJSONFromPoint((Point)feature.getShape()).toString(); else if (getGeometryType()=="esriGeometryMultipoint") geometryStr=ServerUtilities.getJSONFromMultipoint((Multipoint)feature.getShape()).toString(); else if (getGeometryType()=="esriGeometryPolyline") { polyline=(Polyline)feature.getShape(); polyline.generalize(1); geometryStr=ServerUtilities.getJSONFromPolyline(polyline).toString(); } else if (getGeometryType()=="esriGeometryPolygon") { polygon =(Polygon)feature.getShape(); polygon.generalize(1); geometryStr=ServerUtilities.getJSONFromPolygon(polygon).toString(); } else geometryStr =JSONObject.NULL.toString(); attributesStr ="{"; /* * create a JSON text of feature attributes */ for (int i=0; i<fldCount; i++) { field = fields.getField(i); //SHAPE.LENGTH and SHPAE.AREA if (field.getType()!=esriFieldType.esriFieldTypeGeometry && field.getType()!=esriFieldType.esriFieldTypeRaster && field.getType()!=esriFieldType.esriFieldTypeBlob && field.getName().indexOf("SHAPE.")==-1) { if (feature.getValue(i)==null) attributesStr +="\""+field.getName()+"\":"+ JSONObject.NULL.toString()+","; else if (field.getType()==esriFieldType.esriFieldTypeString ||field.getType()==esriFieldType.esriFieldTypeDate) attributesStr +="\""+field.getName()+"\":\""+ feature.getValue(i).toString()+"\","; else attributesStr +="\""+field.getName()+"\":"+ feature.getValue(i).toString()+","; } } /* * add change type to the attributes */ attributesStr +="\"changeType\":"+ changeType +"}"; /* * put geometry and attribute key/value pair together * and form a JSON representation of feature */ featureJSON =new JSONObject(); featureJSON.put("attributes", new JSONObject(attributesStr)); featureJSON.put("geometry", new JSONObject(geometryStr)); //featuresArray is a JSONArray featuresArray.put(featureJSON); feature =(Feature)pCursor.nextFeature(); }
Just want to share with developers what i have learned on maxAllowableOffset. I recently have a project where I need write an ArcObject routine to retrieve a collection of features from a polyline feature class. And then convert them into a featurecollection JSON text (layerdefinition, featureSet etc) so that I can create a feature layer dynamically using this featurecollection. Initially it took around 315 seconds to converting 8 polylines to JSON text. So I added the method Polyline.generalize(double maxAllowableOffset) before the conversion. Now it only takes 18 seconds to convert (5.7% of the previous time!). I am not 100% sure whether the method is what Javascript API maxAllowableOffset internally implemented. However it is amazing how geometry generalization make a huge difference. The method uses widely accepted Douglas-Poiker algorithm for linear simplification. It basically treat the two points within maxAllowableOffset as the same, thus dramatically reduce the number of points in a polyline�??s pointcollection. In my case it reduced the lenght of featurecollection JSON text from 630,681 to 13, 161 and still well preserve the integrity of geometry shape. So I strongly recommend using maxAllowableOffset whenever you can.
maxAllowableOffset isn't specific to feature layers, query and identify tasks can also use it. It's a best practice to use it and I'm pretty sure it'll stop this error from appearing.
Are you displaying the whole layer as a dynamic map service or a feature layer?Are you sure you need to send a 1.5MB geometry to the client? I would guess that you could generalize the feature and this error would go away. Plus, your app would be faster. Both the queryTask and the identifyTask support maxAllowableOffset. Here's a blog post I did on the details of how to calculate a suitable value for maxAllowableOffset: http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2011/06/13/Feature-layers-can-generalize-geometries-on-the-fly.aspxOnce you have a value for maxOffset, set it on your query object or your identifyParameters object.
Do you have a proxy set up for your app?
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
