I created a script to batch process Zonal Statistics as Table with user inputs, option to add a field, and a single appended table as an output.It runs fine with some data. But with other data it throws a ERROR 010423: N:\Gabions\NDVI\35_38_May_June\t_t324 does not have valid statistics as required by the operationWhen I modify the code to run from PyScripter it works fine and doesn't throw the error. (Modifications: hard-code the inputs, change AddMessage/AddWarning to print.) I haven't been able to find much information on this error within a python setting.I tried adding Calculate Statistics just before the Zonal Statistics as Table but nothing changed...arcpy.CalculateStatistics_management(raster,"","","","OVERWRITE",zonefile)I'm pretty new to scripting. Any help?# Import modules
import arcpy
import os
import shutil
# Get parameters
indir = arcpy.GetParameterAsText(0)
zonefile = arcpy.GetParameterAsText(1)
addfield = arcpy.GetParameterAsText(2)
startcharin = arcpy.GetParameterAsText(3)
endcharin = arcpy.GetParameterAsText(4)
outdir = arcpy.GetParameterAsText(5)
outfile = arcpy.GetParameterAsText(6)
# Set variables for zonal statistics and add field routines
zonefield = "UID"
startchar = int(startcharin) - 1
endchar = int(endcharin) - 1
outtable = ""
year = ""
# Set global environments and make scratch
scratchdir = "C:\\TEMP\\Scratch\\ZoneStatsBatch"
if not os.path.exists(scratchdir):
os.makedirs(scratchdir)
# Check the input data
fieldlist = arcpy.ListFields(zonefile,"*","ALL")
fieldnames = []
for field in fieldlist:
fieldnames.append(field.name)
if not "UID" in fieldnames:
arcpy.AddWarning(zonefield + " field does not exist in " + zonefile)
arcpy.env.workspace = indir
rasters = arcpy.ListRasters("*")
if not rasters:
arcpy.AddWarning(indir +" contains no rasters \nZonal statistics failed")
# Zonal Statistics
index = 0
for raster in rasters:
outtable = scratchdir + "\\scratchouttable" + str(index) + ".dbf"
arcpy.sa.ZonalStatisticsAsTable(zonefile,zonefield,raster,outtable,"DATA","ALL")
arcpy.AddMessage("Zonal statistics have been calculated for raster: " + raster)
# Add Field and Calculate Field if addfield boolean = True
if addfield:
try:
year = raster[startchar:endchar]
arcpy.AddField_management(outtable, "Year", "TEXT", "", "", 4)
arcpy.CalculateField_management(outtable, "Year", year, "PYTHON")
arcpy.AddMessage ("Year field (" + year + ") has been calculated for raster: " + raster)
except:
arcpy.AddWarning("Add year field failed")
index = index + 1
# Set local variables and environment for Append
arcpy.env.workspace = scratchdir
outfiledbf = outfile +".dbf"
template = outtable
config_keyword = ""
outfullpath = outdir + "\\" + outfiledbf
schemaType ="NO_TEST"
fieldMappings = ""
subtype = ""
# Append
try:
tablelist = arcpy.ListTables("*")
arcpy.CreateTable_management(outdir, outfiledbf, template, config_keyword)
arcpy.Append_management(tablelist, outfullpath, schemaType, fieldMappings, subtype)
arcpy.AddMessage("Batch zonal statistics output table located at: " + outdir + "\\" + outfiledbf)
except:
arcpy.AddWarning("Table append failed")
# Clean up your mess! (delete scratch)
try:
shutil.rmtree(scratchdir,ignore_errors = "TRUE", onerror = "NONE")
arcpy.AddMessage("Scratch workspace cleared")
except:
arcpy.AddWarning("Scratch workspace not cleared: " + scratchdir)
