Hello!
I received a folder containing a shapefile for Southwest Virginia Base Mapping. It essentially breaks virginia up into a bunch of squares.
What I need is to label those squares by the name assigned to it. If I hover over the squares, the name does pop up, but if I could create a layer that would place all the names in the squares, that would be perfect!
I attached the base file, that should have all the information on it.
