Hi,I have a small extension to create a raster dataset with 5 bands into a GDB. this works no problem, but I am struggling to set the name of each band to the correct name rather than the default 'value'.Does anyone know of a code snippet to set the name of a band?Here is a code snippet to create the bands. It works fine, but the names are unrealistic.//Define the origin for the raster dataset, which is the lower left corner of the raster.
IPoint origin = new PointClass();
origin.PutCoords(lowerLeft.x, lowerLeft.y);
//Define the dimension of the raster dataset.
int width = nColumns; //This is the width of the raster dataset.
int height = nRows; //This is the height of the raster dataset.
double xCell = cellSize; //This is the cell size in x direction.
double yCell = cellSize; //This is the cell size in y direction.
int NumBand = 5; // This is the number of bands the raster dataset contains.
//Create a raster dataset in grid format.
rasterDataset = rasterWs.CreateRasterDataset(rasterFilename, "GRID", origin, width, height, xCell, yCell, NumBand, rstPixelType.PT_FLOAT, sr, true);
//Get the raster band.
IRasterBandCollection rasterBands = (IRasterBandCollection)rasterDataset;
IRasterBand rasterBand;
IRasterProps rasterProps;
rasterBand = rasterBands.Item(0);
rasterProps = (IRasterProps)rasterBand;
//Set NoData if necessary. For a multiband image, NoData value needs to be set for each band.
const double NoDataValue = -9999.99;
rasterProps.NoDataValue = Convert.ToSingle(NoDataValue);
//Create a raster from the dataset.
IRaster raster = rasterDataset.CreateDefaultRaster();
IRasterEdit rasterEdit = (IRasterEdit)raster;
