case "openstreetmap": { var osmLayer:OpenStreetMapLayer = new OpenStreetMapLayer(); osmLayer.id = label; osmLayer.name = label; osmLayer.visible = visible; osmLayer.alpha = alpha; ovMap.addLayer(osmLayer); break; }
import com.esri.ags.layers.OpenStreetMapLayer;
<?xml version="1.0" encoding="utf-8"?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Version 2.1 - Oct 7, 2010 // // Delevoped by Robert Scheitlin // //////////////////////////////////////////////////////////////////////////////// --> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*" layout="horizontal" widgetConfigLoaded="basewidget_widgetConfigLoadedHandler(event)"> <fx:Script> <![CDATA[ import com.esri.ags.events.MapEvent; import com.esri.ags.layers.*; import com.esri.viewer.AppEvent; import com.esri.viewer.ViewerContainer; // Import statements added to allow links in copyright notice import flashx.textLayout.conversion.TextConverter; import flashx.textLayout.elements.TextFlow; // Set the OpenStreetMap copyright notice private var osmHtmlText:String = '© <a href="http://www.openstreetmap.org/" target="_blank">OpenStreetMap</a> contributors, ' + '<a href="http://creativecommons.org/licenses/by-sa/2.0/" target="_blank">CC-BY-SA</a>'; private var osmTF:TextFlow = TextConverter.importToFlow(osmHtmlText, TextConverter.TEXT_FIELD_HTML_FORMAT); protected function basewidget_widgetConfigLoadedHandler(event:Event):void { if (configXML) { const color:String = configXML.label.@color; cright.setStyle("color", toNumber(color.length ? color : "0x000000")); const fontFamily:String = configXML.label.@fontfamily; cright.setStyle("fontFamily", fontFamily.length ? fontFamily : "Verdana"); const fontSize:String = configXML.label.@fontsize; cright.setStyle("fontSize", parseInt(fontSize.length ? fontSize : "9")); const fontWeight:String = configXML.label.@fontweight; cright.setStyle("fontWeight", fontWeight.length ? fontWeight : "bold"); if (map.loaded) { map_loadHandler(null); } else { map.addEventListener(MapEvent.LOAD, map_loadHandler); } } function map_loadHandler(event:MapEvent):void { map.removeEventListener(MapEvent.LOAD, map_loadHandler); ViewerContainer.addEventListener(AppEvent.BASEMAP_SWITCH,basemapSwitched); //Set the copyright text to the first basemap in the list var configBasemaps:Array = configData.basemaps; var label:String = configBasemaps[0].label; var layer:Layer = map.getLayer(label); if (layer is ArcGISTiledMapServiceLayer) { if(layer.visible) cright.text = (layer as ArcGISTiledMapServiceLayer).copyright; } else if (layer is ArcGISDynamicMapServiceLayer) { if(layer.visible) cright.text = (layer as ArcGISDynamicMapServiceLayer).copyright; } else if (layer is ArcGISImageServiceLayer) { if(layer.visible) cright.text = (layer as ArcGISImageServiceLayer).copyright; } // if OpenStreetMapLayer else if (layer is OpenStreetMapLayer) { if(layer.visible) cright.textFlow = osmTF; } } } private function toNumber(value:String):int { if (value.substr(0, 2) == "0x") { return parseInt(value, 16); } return parseInt(value, 10); } protected function basemapSwitched(event:AppEvent):void { var id:String = event.data as String; var configBasemaps:Array = configData.basemaps; if (id) { for (var i:Number = 0; i < configBasemaps.length; i++) { var label:String = configBasemaps.label; var layer:Layer = map.getLayer(label); if (layer is ArcGISTiledMapServiceLayer) { if(layer.visible) cright.text = (layer as ArcGISTiledMapServiceLayer).copyright; } else if (layer is ArcGISDynamicMapServiceLayer) { if(layer.visible) cright.text = (layer as ArcGISDynamicMapServiceLayer).copyright; } else if (layer is ArcGISImageServiceLayer) { if(layer.visible) cright.text = (layer as ArcGISImageServiceLayer).copyright; } // if OpenStreetMapLayer else if (layer is OpenStreetMapLayer) { if(layer.visible) cright.textFlow = osmTF; } } } } ]]> </fx:Script> <viewer:filters> <mx:GlowFilter alpha="1" blurX="3" blurY="3" color="0xFFFFFF" strength="7"/> </viewer:filters> <!--<s:Label id="cright"/>--> <s:RichEditableText id="cright" bottom="2" editable="false" horizontalCenter="0" selectable="false"/> </viewer:BaseWidget>
// new case for OpenStreetMap case "openstreetmap": { var osmLayer:OpenStreetMapLayer = new OpenStreetMapLayer(); osmLayer.id = label; osmLayer.name = label; osmLayer.visible = visible; osmLayer.alpha = alpha; if (operationalLayer) { layerObject.layer = osmLayer; } map.addLayer(osmLayer); break; }
<layer label="OSM" type="openstreetmap" visible="true" alpha="1"/>
switch (type.toLowerCase()) { case "tiled":
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
