Original User: odoeSo, API 2.3 growing pains with my InfoWindows.InfoWindow seems to have gotten an overhaul and been sparked with 2.3, which is awesome.http://help.arcgis.com/en/webapi/flex/apiref/index.html?com/esri/ags/components/supportClasses/infowindow.html&com/esri/ags/components/supportClasses/class-list.htmlUp to this point, the way I have handled InfoWindows was to create a class like thispublic class FeatureInfoWindowRenderer extends SkinnableComponent implements IGraphicRenderer
I set the InfoWindowRenderer as follows.
featureLayer.infoWindowRenderer = new ClassFactory(FeatureInfoWindowRenderer);
Then to make it play nice with the InfoWindow, I added my own data getter/setters for the data object and set it in my graphic setter.
public function set graphic(value:Graphic):void
data = value.attributes;
My InfoWindows can get a little complex, so I actually needed the skinnable comp to add my own custom content that could also be skinned. I set my styles via CSS and the world was a happy place.Since InfoWindow was updated with Spark and now has a Skin, I figured it should impact what I'm doing too much, but I have attached before and after images of the devastation to my InfoWindow.So I figured I'd start fresh, removed all references to ESRI in my CSS and followed one ofthe new 2.3 samples which uses a LabelDataRenderer.So I made a new Rendererpublic class MyFeatureInfoWindowRenderer extends LabelDataRenderer implements IGraphicRenderer
And set the data via the graphic setter as before, as well the label in LabelDataRenderer and what I get is shown in the 3rd image I attached(oops.jpg).So at this point, I'm just confused.Should I be extending the InfoWindowSkin to do this?I'll keep experimenting, but the samples are a little simple and none show if I need to do something special now when using the ClassFactory method of setting the InfoWindow.Thanks.
