Hi Kelly,
This does not work in my application. Is it possible class names or something else changed since 2013?
I'm using API v. 3.10. I don't follow the app.object pattern I just named my object "printer" for the new Printer constructor. I updated your example appropriately in that case, and to use my own png icon. I even added the z-index as you have in html just to be consistent. What happens is this: First, the Print button appears just as it always did. The word Print is there. My png icon is not. When I click the Print button, for a moment it shrinks to ~10px wide, there is no text. Nothing. So it's very skinny. (This is when it would normally say "printing"). Then when it's done, it just disappears. The "Printout" link text never shows up. Thoughts? I'll keep working on this. Conceptually I see what your example is doing. In theory it should be fine, unless something in the API changed. And we have jQuery object scoped into our main JS file with the map object. We are also using bootstrap 3 and storing the tools in the navbar although I don't think that should cause the issue. Basically I'm just wondering if anyone has done this, this year with a recent version of the API. I'll keep working on it, looking at it with the F12 dev tools etc. If I figure it out I'll post back.
Thanks.
update: so far I tried this on ESRI sandbox and JSFiddle. I borrowed ESRI's sample for referencing jquery, grabbed a 48x48 px printer png icon on the Internet and put it on this JS Fiddle. Still not working, it exhibits the behavior described above in Sandbox, and button doesn't even show up at first on Fiddle. Happens with API versions going back to 3.1. I am beginning to think it's a code issue and not a matter of API version.
Edit fiddle - JSFiddle
Looks like you need to set a valid proxy url. To do this you'll need to setup the Esri/resource-proxy · GitHub then specify the location of your proxy at approximately line 75 in your app code.
Perhaps on Fiddle. But, left that in for esri Sandbox which I guess allows you to use ESRI's proxy... I just put it into Fiddle for convenience. But on the ESRI sandbox, the same thing happens: print button has "Print" text, you click it, then nothing in it, then it disappears. Same for my local code, which I had already set up a proxy for, so print could work. (IIS / .Net Proxy) I'll keep testing..
So I read the original post more closely and it looks like you want to change the print text on the widget. The best way to do this is to modify the strings used by the api. Details on how to access the current strings are here:
Default API Strings | Guide | ArcGIS API for JavaScript
And here are the strings associated with the print widget. After requiring the jsapi resources in your app you can modify them as follows.
esriBundle.widgets.print.NLS_print = "My Print";
esriBundle.widgets.print.NLS_printing = "MY Printing";
esriBundle.widgets.print.NLS_printout= "My Printout";
And here's the javascript:
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title></title>
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<link rel="stylesheet" href="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.2/themes/redmond/jquery.ui.all.css">
<script src="http://www.google.com/jsapi?key=ABQIAAAAg58_FLn5bynKiZewfpUCeBTyCV9A2YBg0isNV8i_fASKoO0TiRRYqDCtRVNLgUhnJVaabm69uDjeZg&autoload=%7B%27modules%27%3A%5B%7B%27name%27%3A%27jquery%27%2C%27version%27%3A%271.4.2%27%7D%2C%7B%27name%27%3A%27jqueryui%27%2C%27version%27%3A%271.8.2%27%7D%5D%7D"></script>
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; }
.shadow {
-moz-box-shadow: 0 0 5px #888;
-webkit-box-shadow: 0 0 5px #888;
#map{ margin: 0; padding: 0; }
#feedback {
background: #fff;
color: #000;
position: absolute;
font-family: arial;
height: auto;
right: 20px;
margin: 5px;
padding: 10px;
top: 20px;
width: 300px;
z-index: 40;
#feedback a {
border-bottom: 1px solid #888;
color: #444;
text-decoration: none;
#feedback a:hover, #feedback a:active, #feedback a:visited {
border: none;
#note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; }
#info { padding: 10px 0 0 0; }
</style>
<script src="http://js.arcgis.com/3.10/"></script>
<script>
var app = {};
require([
"esri/map", "esri/layers/FeatureLayer",
"esri/dijit/Print", "esri/tasks/PrintTemplate",
"esri/request", "esri/config", "dojo/i18n!esri/nls/jsapi",
"dojo/_base/array", "dojo/dom", "dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
], function(
Map, FeatureLayer,
Print, PrintTemplate,
esriRequest, esriConfig,esriBundle,
arrayUtils, dom, parser
parser.parse();
dojo.connect(map, "onLoad", function() {
console.log("Map onLoad event");
$(document).ready(jQueryReady);
app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";
esriConfig.defaults.io.proxyUrl = "http://localhost/~kell3008/resource_proxy/proxy.php";
app.map = new esri.Map("map", {
basemap: "hybrid",
center: [-117.447, 33.906],
zoom: 17,
slider: false
// add graphics for pools with permits
var permitUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/MapServer/1";
var poolFeatureLayer = new FeatureLayer(permitUrl, {
"mode": FeatureLayer.MODE_SNAPSHOT
app.map.addLayer(poolFeatureLayer);
// get print templates from the export web map task
var printInfo = esriRequest({
"url": app.printUrl,
"content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
function handlePrintInfo(resp) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
return param.name === "Layout_Template";
if ( layoutTemplate.length == 0 ) {
console.log("print service parameters name for templates must be \"Layout_Template\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
if ( mapOnlyIndex > -1 ) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = arrayUtils.map(templateNames, function(ch) {
var plate = new PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Made by: Esri's JS API Team",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "Pool Permits",
"scalebarUnit": "Miles"
return plate;
// create the print dijit
app.printer = new Print({
"map": app.map,
"templates": templates,
url: app.printUrl
}, dom.byId("print_button"));
app.printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'">
<div id="feedback" class="shadow">
<h3>
Print Templates Created from Info Returned by the Print Service using
<a href="https://developers.arcgis.com/javascript/jsapi/esri.request-amd.html">esri.request</a>
</h3>
<div id="info">
<div id="note">
Note: This sample uses an ArcGIS Server version 10.1 export web map task.
</div>
<!-- that will be used for the print dijit -->
<div id="print_button"></div>
<a href="https://developers.arcgis.com/javascript/jsapi/printtemplate.html">Print templates</a> are generated
from the Export Web Map Task's <a href="http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task">Layout_Template parameter</a>. This info is retrieved from the service
using <a href="https://developers.arcgis.com/javascript/jsapi/esri.request-amd.html">esri.request</a>.
</body>
</html>
Attached is a sample that shows how to make the print button show up in your fiddle and also how to add a print icon.Here are details on the fixes:
And in the sample I attached to my previous email if you don't want the text to display set lines 78-90 equal to an empty string. The problem with setting the printout to an empty string is that you won't have anything to click on when the print is complete because there won't be any text to display for the printout hyperlink.
esriBundle.widgets.print.NLS_print = ""; esriBundle.widgets.print.NLS_printing = ""; esriBundle.widgets.print.NLS_printout= "";
Just wanted to drop back and say thanks again, your solutions worked perfectly! Thanks Kelly and to the rest of the great folks here.
Hello Kelly
I implemented your example code in my app. I am using the proxy provided by ESRI on GitHub in my app because I use secured layers. The problem I have is that Print widget does not work when I using the proxy. Without the proxy I only can load the basemap but the Print Widget works. Can you help me please,
Thank you
Otto
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
