Hi all,
I’ll try to keep this as concise as I can. I am a university student currently in the middle of doing my third year project, due to complications with my original project idea I had to devise something new and the project I am now working on involves GIS analysis using ArcMap.
The analyses I’m trying to carry out seem like they should be simple, however I am a complete novice with GIS and have a very limited understanding of ArcMap (had I known that I’d end up doing a project using GIS I would have taken the relevant course module last academic year), so I am in need of help!
My project is examining how flood risk at a number of UK coastal locations (where there are tidal gauges) will change as mean sea level increases, by comparing tidal records with a high resolution digital elevation model. There are numerous stages to this project, so I’ll just keep my post about the GIS stage.
Here’s a bit of information:
I’m attempting to analyse LiDAR (light detection and ranging) raster land elevation data at 6 UK coastal tidal gauge locations. Data was obtained from Environment Agency’s Geomatics group site.
I have downloaded enough LiDAR data for each location to be able to accommodate a study area of 3km radius at each location.
I want to use ArcMap to perform the following processes and analyses on the data:
1) Import my X/Y coordinates (in the form of British National Grid Easting/Northing) for each coastal location to create a set of point features around which I can create Buffer Zones.
2) Define a ‘study area’ around each location point, thereby enclosing a certain number of ‘elevation data’ raster cells in each study area (ideally each study area would be of a semicircle shape with a radius of 3km around each location point, with the semicircle going inland parallel to the coast; if not a circular study area with a smaller radius will probably suffice)
What I know:
I have been advised that creating these study areas will involve creating a ‘Buffer’ around each location point. I have been advised that I will need to assign a unique ID to each Buffer zone in order to perform my subsequent analyses.
Help needed:
- Is it possible to create a semicircle Buffer zone around a point? How?
- How can I create a Buffer around each individual location point?
- How can I give each Buffer Zone a unique ID, so that for example I can get a ‘Zonal Statistics’ table for each Buffer Zone?
3) Find what % (or at least frequency so that I can work out %) of the raster cells in the study area/buffer lie within different ‘elevation bands’ (I can find the range (min/max) of elevation values in the study buffer using Zonal Statistics as Table, but then I want to see how the elevation values are distributed within the buffer zone so that I can create a histogram; by seeing what % of the raster cells in the study area are within different elevation bands such as 0-5m, 5-10m etc.)
What I know:
I have been advised that this will involve ‘Reclassifying’ the data and finding out the ‘Frequency Distribution’ of values in each Buffer Zone.
Help needed:
- How can I find out how many raster cells overall are enclosed by each study area buffer zone?
- What specific ‘Reclassify’ process do I need to perform in order to find out how the buffer zone elevation data raster cell values are distributed between different elevation bands (the frequency of values in each band)? How do I do this?
(If I know how many raster cells are in each buffer zone overall, and then I can find out what frequency of raster cells fall within different elevation bands, then I can calculate the % values easily).
4) Determine an elevation value below which, for example, 5% of the study area raster cells lie in terms of their data value
What I know: I have been told that this again involves examination of the ‘Frequency Distribution’ of values
Help needed: How do I do this?
5) For any given elevation value (i.e. a calculated elevation value for an average storm tide event at present and then at 10 year intervals in the future), determine what % of the raster cells in each study area lie below or at that value
Ultimately these GIS processes are an attempt to obtain the following information for each location/study area:
- Range of elevation values in the study area, and % values denoting what proportion of study area raster cells in each elevation band (so I can create a basic ‘local land elevation’ Histogram)
- Elevation value (in meters) below which 5% of study area raster cells lie (the lowest 5% of cells; I’ll use this elevation value to look at the Probability of any given monthly extreme tide surpassing this elevation value, seeing if probability increases as tide values are adjusted by expected sea level increase etc.)
- What % of study area raster cells lie below any given elevation value (I’ll calculate the height of an average storm tide event at present, and then at 10/20/30… years in future etc., and then I want to see what % (or frequency, at least) of the study area’s raster cells lie at or below each of these elevation values, so that I can determine how the % of land at risk from flooding will change as mean sea level increases)
So that’s all I’m really trying to find out here!
If anyone can spare 10 minutes to give me guidance on how to do any or all of these analyses, you would be helping me out big time!
As mentioned, I’m basically a beginner with all of this ArcMap stuff, so the more detail you can give the better!
Thank you,
James
