It would be helpful to be able to name the product outputs during the wizard, so they are not named with generic names such as 3D_Mesh.slpk.
Thanks,marc
Hi Marc,
Thanks for reaching out! Can you give us more details on what you have in mind, and also what could be the minimum increment for you? The idea is very valid.
Thanks in advance,
Damian
Hi Damian,
I think the user should be able to have full control over the name of the output reality products, in the same way we can name output feature classes or rasters or any other analysis output in ArcGIS Pro.
This also applies to outputs in the ArcGIS Reality for ArcGIS Pro extension.
Marc
Thanks. Would a way of specifying a naming scheme as prefix be sufficient for you? E.g. "ProjectXXXX_" before each result?
Best,
投稿、コンテンツのフォローなどにはサインインしてください。初めてですか?無料で登録しましょう。
