Is there a way to add a symbology for points that have a specific attribute when the layer already has a symbology set on a certain field? A layer I use already has symbology set to a specific field named "Planting Season". However, I'd like to create a different symbol for points that have the value "Stump" under the "Genus" field. Is this possible to do if the current symbology is sourced from the Planting Season field?
I have looked at the symbol properties that can be changed based on attribute values but I am looking to use a different symbol entirely. The current symbology based on planting season uses solid-fill dots, and I would like to use a different symbol. Below is an example of the current symbology that's based on the "Planting season" field and how it uses solid-fill dots. Could I create a rule or something that uses a different symbol for points labeled as "Stump" under the field called "Genus"?
