Hi, I'm using the append tool to update some data. I have entered an sql expression to filter the input data, but the tool completely ignored it and updated all records!
In one case the expression was "NAME <> ' '", in another "SHORTNAME IS NOT NULL". Both resulted in records being overwritten with blanks and nulls, respectively.
I'm also using a field map and a matching field.
Feature classes are in different geodatabases, editor tracking is active on the target feature class. Using AGP 3.6.2
Also: It would be great if there was an update tool, without the insert, or an option within the append tool to disable insert (though the tool name would be misleading in that case). I keep deleting the inserted rows because I only want the update.
