Survey123 Connect Form. Using Begin Repeat and End Repeat for IMGs. Accessing repeat photos via Map Viewer Popup or Experience Builder List Widget.
I have tried several different arcade elements in the popup or attribute expressions and cannot access the attachments on the repeat table for my survey. I have also tried this in Experience builder (EB) with the list widget, and I cannot set it up to retrieve the photo for the attribute survey record. In EB the list widget will retrieve the first attachment for the entire repeat table and just use it for all records in the list. Looking for documentation to help me work this out, or if anyone has solved, please share.
Thank you
